Datasheet Texas Instruments TMS37F128 — Даташит
СерияTMS37F128
Устройство идентификации удаленного доступа к контроллеру
TMS37F128 Controller Remote Access Identification Device datasheet
PDF, 225 Кб, Файл опубликован: 24 май 2012
TMS37F128D3IDBTRG4
Статус продуктаВ производстве
TMS37F128D3IDBTRG4
N1
Pin44
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
Маркировка37F128D3
Width (мм)4.4
Length (мм)11
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
TMS37F128D3IDBTRG4
  • Passive Go Transponder With Novel Bi-Directional Low Frequency Communications
    PDF, 4.7 Мб, Файл опубликован: 24 июл 2012
    In recent years, Passive Go (PG) systems for motorcycles have been developed that have been copied from automotive Passive Entry and Passive Start (PEPS) systems. But for bikes with no requirement to unlock doors or roll down windows at a distance, such systems are over-designed with their UHF uplinks. The MCU RF group at Texas Instruments has developed a complete low-frequency approach to this pr
  • 3D Analog Front End: Migrating From TMS37122 and TMS37127 to TMS37126D3
    PDF, 315 Кб, Файл опубликован: 9 авг 2012
    The TMS37122, TMS37127 and TMS37126 devices belong to the Passive Entry and Passive Start (PEPS) product family used mainly for automotive applications. These devices are also usable in industrial applications for similar functionality.Since the TMS37122 and TMS37127 devices are becoming obsolete, this application report describes how to migrate to the TMS37126D3 device as a replacement.
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
  • TMS3705 Range Extender Power Solution Using UCC27424-Q1
    PDF, 396 Кб, Файл опубликован: 9 авг 2012
    This application report provides supplementary information about the Texas Instruments 134.2 kHz RFID Base Station IC TMS3705x in combination with an external driver IC. In particular, the document shows a low cost and easy-to-implement solution to improve the communication distance between the transaction processor (TRP) and the Reader unit.
Серия: TMS37F128 (1)
  • Semiconductors> Wireless Connectivity> NFC / RFID
На английском языке: Datasheet Texas Instruments TMS37F128
