Datasheet Texas Instruments TMS37F158LGIDBTRG4 — Даташит
СерияTMS37F158
МодельTMS37F158LGIDBTRG4
Входное устройство контроллера со встроенной аутентификацией DST80, EEPROM, низкочастотным иммобилайзером IF 30-TSSOP
TMS37F158 Controller Entry Device With DST80 Auth, EEPROM, LF Immobilizer IF datasheet
PDF, 126 Кб, Файл опубликован: 24 май 2012
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
Маркировка37F158LG
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • TMS3705 Range Extender Power Solution Using UCC27424-Q1
    PDF, 396 Кб, Файл опубликован: 9 авг 2012
    This application report provides supplementary information about the Texas Instruments 134.2 kHz RFID Base Station IC TMS3705x in combination with an external driver IC. In particular, the document shows a low cost and easy-to-implement solution to improve the communication distance between the transaction processor (TRP) and the Reader unit.
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
Серия: TMS37F158 (1)
  • TMS37F158LGIDBTRG4
  • Semiconductors > Wireless Connectivity > NFC / RFID
На английском языке: Datasheet Texas Instruments TMS37F158LGIDBTRG4
