Datasheet Texas Instruments TMS470R1B512 — Даташит
| Серия | TMS470R1B512 |
16/32-битный RISC-флэш-микроконтроллер
TMS470R1B512 datasheet
PDF, 477 Кб, Версия: A, Файл опубликован: 1 авг 2006
Купить TMS470R1B512 на РадиоЛоцман.Цены — от 65 до 3 395 ₽13 предложений от 13 поставщиков IC MCU 32BIT 512KB FLASH 144LQFP. ARM7® TMS470 Microcontroller IC 16/32-Bit 60MHz 512KB (512K x 8) FLASH 144-LQFP (20x20). Embedded -... | |||
| TMS470R1B512PGET Texas Instruments | 510 ₽ | ||
| TMS470R1B512PGET Texas Instruments | 635 ₽ | ||
| TMS470R1B512PGET Texas Instruments | 1 615 ₽ | ||
| TMS470R1B512PGET Texas Instruments | 1 767 ₽ | ||
| TMS470R1B512PGET | |
| Статус продукта | Не рекомендуется для новых разработок |
| N | 1 |
| Pin | 144 |
| Package Type | PGE |
| Industry STD Term | LQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 60 |
| Carrier | JEDEC TRAY (5+1) |
| Маркировка | TMS470 |
| Width (мм) | 20 |
| Length (мм) | 20 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
- Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUsPDF, 61 Кб, Файл опубликован: 17 ноя 2011
The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further. - 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1B512 (1)
- Semiconductors> Microcontrollers (MCU)> Other Microcontrollers> TMS470 ARM7TDMIВ®-Based Industrial MCUs
