Datasheet Texas Instruments TMS570LS20206-EP — Даташит
СерияTMS570LS20206-EP
Усовершенствованный продукт: 16- и 32-битный флэш-микроконтроллер RISC
TMS570LS20206-EP, TMS570LS20216-EP 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 2 авг 2012
S5LS20206ASGWTMEPS5LS20206ASPGEMEPV62/12622-01XEV62/12622-01YE
Статус продуктаВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНетНет
N1234
Pin337144144337
Package TypeGWTPGEPGEGWT
Industry STD TermNFBGALQFPLQFPNFBGA
JEDEC CodeS-PBGA-NS-PQFP-GS-PQFP-GS-PBGA-N
Package QTY90606090
CarrierJEDEC TRAY (5+1)TUBETUBEJEDEC TRAY (5+1)
МаркировкаS20206ASGWTMEPTMS570LSS20206ASPGEMEPS20206ASGWTMEP
Width (мм)16202016
Length (мм)16202016
Thickness (мм).91.41.4.9
Pitch (мм).8.5.5.8
Max Height (мм)1.41.61.61.4
RoHSSee ti.comСовместимСовместимSee ti.com
  • Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HET
    PDF, 476 Кб, Файл опубликован: 1 май 2015
    This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system s
  • Sine Wave Generation Using PWM With Hercules N2HET and HTU
    PDF, 371 Кб, Файл опубликован: 12 май 2015
    This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as we
  • Semiconductors> Space & High Reliability> Microcontroller> Performance MCU> Safety Products
На английском языке: Datasheet Texas Instruments TMS570LS20206-EP
Публикации по теме
