Datasheet Texas Instruments TMS570LS20216-EP — Даташит
СерияTMS570LS20216-EP
Усовершенствованный продукт: 16- и 32-битный флэш-микроконтроллер RISC
TMS570LS20206-EP, TMS570LS20216-EP 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 2 авг 2012
TMS570LS20216
S5LS20216ASGWTMEPS5LS20216ASPGEMEPV62/12622-02XEV62/12622-02YE
Статус продуктаВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетНетНет
N1234
Pin337144144337
Package TypeGWTPGEPGEGWT
Industry STD TermNFBGALQFPLQFPNFBGA
JEDEC CodeS-PBGA-NS-PQFP-GS-PQFP-GS-PBGA-N
Package QTY90606090
CarrierJEDEC TRAY (5+1)TUBETUBEJEDEC TRAY (5+1)
МаркировкаS20216ASGWTMEPTMS570LSS20216ASPGEMEPS20216ASGWTMEP
Width (мм)16202016
Length (мм)16202016
Thickness (мм).91.41.4.9
Pitch (мм).8.5.5.8
Max Height (мм)1.41.61.61.4
RoHSSee ti.comСовместимСовместимSee ti.com
  • Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HET
    PDF, 476 Кб, Файл опубликован: 1 май 2015
    This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system s
  • High Speed Serial Bus Using the MibSPIP Module on Hercules-Based MCUs
    PDF, 804 Кб, Файл опубликован: 22 апр 2016
    This application report describes how the Multi-Buffered Serial Peripheral Interface Module (MibSPIP) and the DMA modules found on many devices of the Hercules MCU family can be used to autonomously transfer data from and into the device embedded RAM. In addition to this, the parallel pin option of the MibSPIP module will be covered and used to increase the speed of the SPI link. This technique co
  • Sine Wave Generation Using PWM With Hercules N2HET and HTU
    PDF, 371 Кб, Файл опубликован: 12 май 2015
    This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as we
  • Using the CRC Module on Herculesв„ў-Based Microcontrollers
    PDF, 113 Кб, Файл опубликован: 4 авг 2016
    This application report describes how the to use the embedded CRC module found on all Hercules devices, as well as how to calculate a signature for non-volatile memory with the TI ARMВ® Code Gen Tools Linker.
  • Semiconductors> Space & High Reliability> Microcontroller> Performance MCU> Safety Products
На английском языке: Datasheet Texas Instruments TMS570LS20216-EP
Публикации по теме
