Datasheet Linear Technology LT1001CN8#PBF — Даташит
| Серия | LT1001 |
| Модель | LT1001CN8#PBF |
Прецизионный операционный усилитель
Datasheet LT1001
PDF, 202 Кб, Язык: анг., Файл закачен: 21 апр 2017, Страниц: 16
Precision Operational Amplifier
- Methods for Measuring Op Amp Settling Time &mdash AN10PDF, 277 Кб, Файл опубликован: 1 июл 1985
The AN10 begins with a survey of methods for measuring op amp settling time. This commentary develops into circuits for measuring settling time to 0.0005%. Construction details and results are presented. Appended sections cover oscilloscope overload limitations and amplifier frequency compensation.Выписка из документа - Circuit Techniques for Clock Sources &mdash AN12PDF, 150 Кб, Файл опубликован: 1 окт 1985
Circuits for clock sources are presented. Special attention is given to crystal-based designs including TXCOs and VXCOs.Выписка из документа - Composite Amplifiers &mdash AN21PDF, 330 Кб, Файл опубликован: 1 июл 1986
Applications often require an amplifier that has extremely high performance in several areas. For example, high speed and DC precision are often needed. If a single device cannot simultaneously achieve the desired characteristics, a composite amplifier made up of two (or more) devices can be configured to do the job. AN21 shows examples of composite approaches in designs combining speed, precision, low noise and high power.Выписка из документа - Thermocouple Measurement &mdash AN28PDF, 988 Кб, Файл опубликован: 1 фев 1988
Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.Выписка из документа - Applications for a Switched-Capacitor Instrumentation Building Block &mdash AN3PDF, 1.5 Мб, Файл опубликован: 1 июл 1985
This application note describes a wide range of useful applications for the LTC1043 dual precision instrumentation switched capacitor building block. Some of the applications described are ultra high performance instrumentation amplifier, lock-in amplifier, wide range digitally controlled variable gain amplifier, relative humidity sensor signal conditioner, LVDT signal conditioner, charge pump F/V and V/F converters, 12-bit A/D converter and more.Выписка из документа - Thermal Techniques in Measurement and Control Circuitry &mdash AN5PDF, 175 Кб, Файл опубликован: 1 дек 1984
6 applications utilizing thermally based circuits are detailed. Included are a 50MHz RMS to DC converter, and anemometer, a liquid flow meter and others. A general discussion of thermodynamic considerations involved in circuitry is also presented.Выписка из документа - Applications of New Precision Op Amps &mdash AN6PDF, 784 Кб, Файл опубликован: 1 янв 1985
Application considerations and circuits for the LT1001 and LT1002 single and dual precision amplifiers are illustrated in a number of circuits, including strain gauge signal conditioners, linearized platinum RTD circuits, an ultra precision dead zone circuit for motor servos and other examples. - Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74PDF, 980 Кб, Файл опубликован: 1 июл 1998
DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.Выписка из документа - A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86PDF, 540 Кб, Файл опубликован: 1 янв 2001
This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.Выписка из документа
Design Notes
- Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140PDF, 74 Кб, Файл опубликован: 1 окт 1996Выписка из документа
- Noise Calculations in Op Amp Circuits &mdash DN15PDF, 224 Кб, Файл опубликован: 1 сен 1988Выписка из документа
- Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3PDF, 224 Кб, Файл опубликован: 1 окт 1987Выписка из документа
- Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42PDF, 70 Кб, Файл опубликован: 1 дек 1990Выписка из документа
- Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6PDF, 137 Кб, Файл опубликован: 1 янв 1988
Статьи
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT JournalPDF, 262 Кб, Файл опубликован: 1 авг 1998Выписка из документа
Серия: LT1001 (4)
- LT1001ACN8#PBF LT1001CN8#PBF LT1001CS8#PBF LT1001CS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Noise Amplifiers ( | High Voltage Amplifiers (>12V)
LT1001CN8PBF, LT1001CN8 PBF
