Datasheet Linear Technology LT1001CS8#TRPBF — Даташит
СерияLT1001
МодельLT1001CS8#TRPBF
Прецизионный операционный усилитель
Datasheet LT1001
PDF, 202 Кб, Язык: анг., Файл закачен: 21 апр 2017, Страниц: 16
Precision Operational Amplifier
  • Methods for Measuring Op Amp Settling Time &mdash AN10
    PDF, 277 Кб, Файл опубликован: 1 июл 1985
    The AN10 begins with a survey of methods for measuring op amp settling time. This commentary develops into circuits for measuring settling time to 0.0005%. Construction details and results are presented. Appended sections cover oscilloscope overload limitations and amplifier frequency compensation.
  • Circuit Techniques for Clock Sources &mdash AN12
    PDF, 150 Кб, Файл опубликован: 1 окт 1985
    Circuits for clock sources are presented. Special attention is given to crystal-based designs including TXCOs and VXCOs.
  • Composite Amplifiers &mdash AN21
    PDF, 330 Кб, Файл опубликован: 1 июл 1986
    Applications often require an amplifier that has extremely high performance in several areas. For example, high speed and DC precision are often needed. If a single device cannot simultaneously achieve the desired characteristics, a composite amplifier made up of two (or more) devices can be configured to do the job. AN21 shows examples of composite approaches in designs combining speed, precision, low noise and high power.
  • Thermocouple Measurement &mdash AN28
    PDF, 988 Кб, Файл опубликован: 1 фев 1988
    Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.
  • Applications for a Switched-Capacitor Instrumentation Building Block &mdash AN3
    PDF, 1.5 Мб, Файл опубликован: 1 июл 1985
    This application note describes a wide range of useful applications for the LTC1043 dual precision instrumentation switched capacitor building block. Some of the applications described are ultra high performance instrumentation amplifier, lock-in amplifier, wide range digitally controlled variable gain amplifier, relative humidity sensor signal conditioner, LVDT signal conditioner, charge pump F/V and V/F converters, 12-bit A/D converter and more.
  • Thermal Techniques in Measurement and Control Circuitry &mdash AN5
    PDF, 175 Кб, Файл опубликован: 1 дек 1984
    6 applications utilizing thermally based circuits are detailed. Included are a 50MHz RMS to DC converter, and anemometer, a liquid flow meter and others. A general discussion of thermodynamic considerations involved in circuitry is also presented.
  • Applications of New Precision Op Amps &mdash AN6
    PDF, 784 Кб, Файл опубликован: 1 янв 1985
    Application considerations and circuits for the LT1001 and LT1002 single and dual precision amplifiers are illustrated in a number of circuits, including strain gauge signal conditioners, linearized platinum RTD circuits, an ultra precision dead zone circuit for motor servos and other examples.
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
Design Notes
  • Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140
    PDF, 74 Кб, Файл опубликован: 1 окт 1996
  • Noise Calculations in Op Amp Circuits &mdash DN15
    PDF, 224 Кб, Файл опубликован: 1 сен 1988
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3
    PDF, 224 Кб, Файл опубликован: 1 окт 1987
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6
    PDF, 137 Кб, Файл опубликован: 1 янв 1988
Статьи
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT Journal
    PDF, 262 Кб, Файл опубликован: 1 авг 1998
Серия: LT1001 (4)
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Noise Amplifiers ( | High Voltage Amplifiers (>12V)
LT1001CS8TRPBF, LT1001CS8 TRPBF
На английском языке: Datasheet Linear Technology LT1001CS8#TRPBF
Политика конфиденциальности
