Datasheet Linear Technology LT1037CS8#TRPBF — Даташит
СерияLT1037
МодельLT1037CS8#TRPBF
Малошумящие высокоскоростные прецизионные операционные усилители
Datasheet LT1007, LT1037
PDF, 532 Кб, Язык: анг., Файл закачен: 27 июл 2017, Страниц: 16
Low Noise, High Speed Precision Operational Amplifiers
33 предложений от 14 поставщиков
LT1037CS8#TRPBF
от 84 ₽
LT1037CS8#TRPBF
146 ₽
LT1037CS8#TRPBF
159 ₽
SUV System
LT1037CS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW60 МГц
Av Min Stable5 V/V
Avol86 дБ
CMRR130 дБ
Cload100 пФ
Demo BoardsDC417B
Design ToolsLTspice File
Enoise 1/f Corner2 Hz
Enoise Density2.5 нВ/rtГц
Экспортный контрольнет
Ibias10 нА
Inoise0.4 пА/rtГц
Inoise 1/f Corner120 Hz
Ios0.007 мкА
Iout20.8 мА
Isupply2.6 мА
LF Enoise0.06 µVPP
Over-the-Topнет
PSRR130 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR15 В/мс
Shutdownнет
Single Supplyнет
ТипVFB
VinCM High (from V+)2.5 В
VinCM Low (from V-)2 В
Voh (from V+)1.2 В
Vol (from V-)1.2 В
Vos0.01 мВ
Vos TC0.2 мВ/C
Vs макс.44 В
Vs мин.8 В
LT1007 LT1007
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Thermal Techniques in Measurement and Control Circuitry &mdash AN5
    PDF, 175 Кб, Файл опубликован: 1 дек 1984
    6 applications utilizing thermally based circuits are detailed. Included are a 50MHz RMS to DC converter, and anemometer, a liquid flow meter and others. A general discussion of thermodynamic considerations involved in circuitry is also presented.
Design Notes
  • Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140
    PDF, 74 Кб, Файл опубликован: 1 окт 1996
  • Noise Calculations in Op Amp Circuits &mdash DN15
    PDF, 224 Кб, Файл опубликован: 1 сен 1988
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3
    PDF, 224 Кб, Файл опубликован: 1 окт 1987
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6
    PDF, 137 Кб, Файл опубликован: 1 янв 1988
Статьи
  • Consider New Precision Amplifiers for Updated Industrial Equipment Designs &mdash LT Journal
    PDF, 154 Кб, Файл опубликован: 1 сен 2009
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Noise Amplifiers ( | High Voltage Amplifiers (>12V) | High Speed Amplifiers (GBW > 50MHz)
  • Space & Harsh Environment > Military Hermetic (M)
LT1037CS8TRPBF, LT1037CS8 TRPBF
На английском языке: Datasheet Linear Technology LT1037CS8#TRPBF
Публикации по теме
