Datasheet Linear Technology LT1057S8#PBF — Даташит
СерияLT1057
МодельLT1057S8#PBF
Высокоскоростные операционные усилители с двойным и четырехканальным входом JFET
Datasheet LT1057, LT1058
PDF, 340 Кб, Язык: анг., Файл закачен: 28 июл 2017, Страниц: 16
Dual and Quad, JFET Input Precision High Speed Op Amps
42 предложений от 22 поставщиков
727GS
LT1057S8#PBF
от 225 ₽
LT1057S8
234 ₽
LT1057S8
252 ₽
ЗУМ-СМД
LT1057S8#PBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов2
Частота единичного усиления GBW5 МГц
Av Min Stable1 V/V
Avol51 дБ
CMRR100 дБ
Cload8000 пФ
Design ToolsLTspice Model
Enoise 1/f Corner28 Hz
Enoise Density13 нВ/rtГц
Экспортный контрольнет
Ibias0.005 нА
Inoise0.0015 пА/rtГц
Inoise 1/f Corner0.1 Hz
Ios0.000003 мкА
Iout20 мА
Isupply1.6 мА
LF Enoise2 µVPP
Over-the-Topнет
PSRR103 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR14 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)600 нс
ТипJFET, VFB
VinCM High (from V+)0.7 В
VinCM Low (from V-)3.5 В
Voh (from V+)2 В
Vol (from V-)2 В
Vos0.15 мВ
Vos TC3 мВ/C
Vs макс.40 В
Vs мин.8 В
LT1058 LT1058
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
Design Notes
  • Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140
    PDF, 74 Кб, Файл опубликован: 1 окт 1996
  • Noise Calculations in Op Amp Circuits &mdash DN15
    PDF, 224 Кб, Файл опубликован: 1 сен 1988
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3
    PDF, 224 Кб, Файл опубликован: 1 окт 1987
  • Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6
    PDF, 137 Кб, Файл опубликован: 1 янв 1988
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | Low Bias Current Amplifiers (Ib < 100pA) | JFET Input Amplifiers
  • Space & Harsh Environment > Military Hermetic (M)
LT1057S8PBF, LT1057S8 PBF
На английском языке: Datasheet Linear Technology LT1057S8#PBF
