Datasheet Linear Technology LT1077IS8#PBF — Даташит
СерияLT1077
МодельLT1077IS8#PBF
Micropower, один источник питания, прецизионный операционный усилитель
Datasheet LT1077
PDF, 309 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 16
Micropower, Single Supply, Precision Op Amp
33 предложений от 20 поставщиков
IC OPAMP GP 1 CIRCUIT 8SO. General Purpose Amplifier 1 Circuit 8-SO. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LT1077IS8
199 ₽
727GS
LT1077IS8
LT1077IS8#TRPBF
LT1077IS8/ACS8/CS8
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW0.23 МГц
Av Min Stable1 V/V
Avol60 дБ
CMRR106 дБ
Cload1500 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise 1/f Corner0.7 Hz
Enoise Density27 нВ/rtГц
Экспортный контрольнет
Ibias7 нА
Inoise0.065 пА/rtГц
Inoise 1/f Corner95 Hz
Ios0.00000008 мкА
Iout25 мА
Isupply0.048 мА
LF Enoise0.5 µVPP
Over-the-Topнет
PSRR118 дБ
Rail-to-RailIn to V-
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR0.08 В/мс
Shutdownнет
Single Supplyда
ТипVFB
VinCM High (from V+)1.2 В
VinCM Low (from V-)-0.3 В
Vos0.009 мВ
Vos TC0.4 мВ/C
Vs макс.44 В
Vs мин.2.2 В
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Techniques for 92% Efficient LCD Illumination &mdash AN55
    PDF, 688 Кб, Файл опубликован: 1 авг 1993
    This publication details several LCD backlight circuits which feature 92% efficiency. Other benefits include low voltage operation, synchronizing capability, higher output power for color displays, and extended dimming range. Extensive coverage of practical issues includes layout problems, multi-lamp displays, safety and reliability concerns and efficiency and photometric measurements. Also included is a review of circuits which did not work along with appropriate commentary.
  • Using the LTC1325 Battery Management IC: &mdash AN64
    PDF, 385 Кб, Файл опубликован: 2 авг 1996
    Application Note 64 details characteristics of various battery types and appropriate charging management schemes. The LTC1325 battery management IC is highlighted along with information for applying it to any type battery. Techniques and circuitry for conditioning, charging and monitoring NiCd, NiMH, Li-Ion and Lead-Acid batteries are presented.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • A Seven-Nanosecond Comparator for Single Supply Operation &mdash AN72
    PDF, 882 Кб, Файл опубликован: 1 май 1998
    AN72 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section uses the 7ns LT1394 in V-to-F converters, crystal oscillators, clock skew generators, triggers, sampling configurations and a nanosecond pulse stretcher. Appendices cover related topics.
  • Bias Voltage and Current Sense Circuits for Avalanche Photodiodes &mdash AN92
    PDF, 1.1 Мб, Файл опубликован: 1 ноя 2002
    Avalanche photodiodes, used in laser based fiberoptic systems, require high voltage bias and accurate, wide range current monitoring. Bias voltage varies from 15V-90V and current ranges from 100nA to 1mA, a 10,000:1 dynamic range. This publication presents various 5 volt powered circuits which meet these requirements. Appended sections detail specific circuit techniques and cover measurement practice.
Design Notes
  • The LTC1446/LTC1446L: World's First Dual 12-Bit DACs in SO-8 &mdash DN131
    PDF, 77 Кб, Файл опубликован: 3 июн 1996
  • Micropower, Single Supply Applications: (1) A Self-Biased, Buffered Reference (2) Megaohm Input Impedance Difference Amplifier &mdash DN23
    PDF, 199 Кб, Файл опубликован: 1 июн 1989
  • A Single Amplifier, Precision High Voltage Instrument Amp &mdash DN25
    PDF, 71 Кб, Файл опубликован: 1 авг 1989
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • 3V Operation of Linear Technology Op Amps &mdash DN56
    PDF, 78 Кб, Файл опубликован: 1 фев 1992
  • 12-Bit Rail-to-Rail Micropower DACs in an SO-8 &mdash DN96
    PDF, 76 Кб, Файл опубликован: 1 фев 1995
Статьи
  • Infinite Sample-and-Hold Outperforms Many Legacy Sample-and-Hold Amplifiers &mdash LT Journal
    PDF, 159 Кб, Файл опубликован: 1 ноя 2000
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Low Power Amplifiers (Is < 1mA/amp)
LT1077IS8PBF, LT1077IS8 PBF
На английском языке: Datasheet Linear Technology LT1077IS8#PBF
