Datasheet Linear Technology LT1078SW#TRPBF — Даташит
СерияLT1078
МодельLT1078SW#TRPBF
Micropower, Dual, Single Supply, Прецизионные операционные усилители
Datasheet LT1078, LT1079
PDF, 618 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 20
Micropower, Dual and Quad, Single Supply, Precision Op Amps
IC OPAMP GP 2 CIRCUIT 16SO. General Purpose Amplifier 2 Circuit 16-SO. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LT1078SW#TRPBF
242 ₽
LT1078SW#TRPBF
SUV System
LT1078SW#TRPBF
LT1078SW#TRPBF
КорпусSW-16
Код корпусаSW
Индекс корпуса05-08-1620 (SW16)
Количество каналов2
Частота единичного усиления GBW0.2 МГц
Av Min Stable1 V/V
Avol60 дБ
CMRR110 дБ
Cload1800 пФ
Design ToolsLTspice File
Enoise 1/f Corner0.7 Hz
Enoise Density28 нВ/rtГц
Экспортный контрольнет
Ibias6 нА
Inoise0.06 пА/rtГц
Inoise 1/f Corner95 Hz
Ios0.00005 мкА
Iout15 мА
Isupply0.038 мА
LF Enoise0.6 µVPP
Over-the-Topнет
PSRR114 дБ
Rail-to-RailIn to V-
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR0.07 В/мс
Shutdownнет
Single Supplyда
ТипVFB
VinCM High (from V+)1.2 В
VinCM Low (from V-)-0.3 В
Vos0.03 мВ
Vos TC0.4 мВ/C
Vs макс.44 В
Vs мин.2.2 В
LT1079 LT1079
  • Risk Assessment Advice for High Reliability Amplifiers &mdash AN141
    PDF, 299 Кб, Файл опубликован: 7 окт 2013
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Measurement and Control Circuit Collection &mdash AN45
    PDF, 1.2 Мб, Файл опубликован: 5 июн 1991
    A variety of measurement and control circuits are included in this application note. Eighteen circuits, including ultra low noise amplifiers, current sources, transducer signal conditioners, oscillators, data converters and power supplies are presented. The circuits emphasize precision specifications with relatively simple configurations.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Practical Circuitry for Measurement and Control Problems &mdash AN61
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1994
    This collection of circuits was worked out between June 1991 and July of 1994. Most were designed at customer request or are derivatives of such efforts. Types of circuits include power converters, transducer signal conditioners, amplifiers and signal generators. Specific circuits include low noise amplifiers, high power single cell DC/DC converters, portable high accuracy barometers, a 10mHz 1% accuracy RMS/DC converter, and random noise generators. Appended sections cover noise theory and present a historical perspective of wideband amplifiers.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • Bias Voltage and Current Sense Circuits for Avalanche Photodiodes &mdash AN92
    PDF, 1.1 Мб, Файл опубликован: 1 ноя 2002
    Avalanche photodiodes, used in laser based fiberoptic systems, require high voltage bias and accurate, wide range current monitoring. Bias voltage varies from 15V-90V and current ranges from 100nA to 1mA, a 10,000:1 dynamic range. This publication presents various 5 volt powered circuits which meet these requirements. Appended sections detail specific circuit techniques and cover measurement practice.
Design Notes
  • Micropower, Single Supply Applications: (1) A Self-Biased, Buffered Reference (2) Megaohm Input Impedance Difference Amplifier &mdash DN23
    PDF, 199 Кб, Файл опубликован: 1 июн 1989
  • Designing with a New Family of Instrumentation Amplifiers &mdash DN40
    PDF, 554 Кб, Файл опубликован: 1 окт 1990
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • Signal Conditioning for Platinum Temperature Transducers &mdash DN45
    PDF, 69 Кб, Файл опубликован: 1 мар 1991
  • 3V Operation of Linear Technology Op Amps &mdash DN56
    PDF, 78 Кб, Файл опубликован: 1 фев 1992
Статьи
  • Consider New Precision Amplifiers for Updated Industrial Equipment Designs &mdash LT Journal
    PDF, 154 Кб, Файл опубликован: 1 сен 2009
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | Precision Amplifiers (Vos | Low Power Amplifiers (Is < 1mA/amp)
LT1078SWTRPBF, LT1078SW TRPBF
На английском языке: Datasheet Linear Technology LT1078SW#TRPBF
