Datasheet Linear Technology LT1178SW#TRPBF — Даташит
СерияLT1178
МодельLT1178SW#TRPBF
Макс. 17 мкА, двойной, одинарный, прецизионные операционные усилители
Datasheet LT1178, LT1179
PDF, 247 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 12
17µA Max, Dual and Quad, Single Supply, Precision Op Amps
, Op Amp Dual Precision Amplifier ±22V/44V 16-Pin SOIC W T/R
LT1178SW#TRPBF
288 ₽
LT1178SW#TRPBF
468 ₽
SUV System
LT1178SW#TRPBF
LT1178SW#TRPBF
КорпусSW-16
Код корпусаSW
Индекс корпуса05-08-1620 (SW16)
Количество каналов2
Частота единичного усиления GBW0.085 МГц
Av Min Stable1 V/V
Avol68 дБ
CMRR106 дБ
Cload2500 пФ
Design ToolsLTspice Model
Enoise 1/f Corner0.5 Hz
Enoise Density49 нВ/rtГц
Экспортный контрольнет
Ibias3 нА
Inoise0.01 пА/rtГц
Inoise 1/f Corner30 Hz
Ios0.00005 мкА
Iout30 мА
Isupply0.012 мА
LF Enoise0.9 µVPP
Over-the-Topнет
PSRR112 дБ
Rail-to-RailIn to V-
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR0.04 В/мс
Shutdownнет
Single Supplyда
ТипVFB
VinCM High (from V+)1.1 В
VinCM Low (from V-)-0.3 В
Voh (from V+)1.6 В
Vol (from V-)0.0002 В
Vos0.03 мВ
Vos TC0.6 мВ/C
Vs макс.44 В
Vs мин.2 В
LT1179 LT1179
  • Voltage Reference Circuit Collection &mdash AN42
    PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
    A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Applications of the LT1300 and LT1301 Micropower DC/DC Converters &mdash AN59
    PDF, 213 Кб, Файл опубликован: 1 янв 1994
    This note covers operation and applications of the LT1300 and LT1301 high efficiency micropower step-up DC/DC converter ICs. Internal operation of the ICs is described in detail. A variety of applications are presented, ranging from straightforward 2-cell to 5V converters and 5V to 12V converters to exotic transducerbased circuits such as flame detectors and CCFL drivers. Converters from both 2-cell and 4-cell inputs are included. Operating hours at various load currents are presented and relative merits of different battery types are discussed.
Design Notes
  • Micropower, Single Supply Applications: (1) A Self-Biased, Buffered Reference (2) Megaohm Input Impedance Difference Amplifier &mdash DN23
    PDF, 199 Кб, Файл опубликован: 1 июн 1989
  • Applications for a New Micropower, Low Charge Injection Analog Switch &mdash DN38
    PDF, 77 Кб, Файл опубликован: 1 авг 1990
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • 3V Operation of Linear Technology Op Amps &mdash DN56
    PDF, 78 Кб, Файл опубликован: 1 фев 1992
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Low Power Amplifiers (Is < 1mA/amp)
LT1178SWTRPBF, LT1178SW TRPBF
На английском языке: Datasheet Linear Technology LT1178SW#TRPBF
Публикации по теме
