Datasheet Linear Technology LT1206CR#PBF — Даташит
СерияLT1206
МодельLT1206CR#PBF
Усилитель с обратной связью по току 250 мА / 60 МГц
Datasheet LT1206
PDF, 372 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 18
250mA/60MHz Current Feedback Amplifier
44 предложений от 23 поставщиков
LT1206CR#TR
1 113 ₽
LT1206CR#TRPBF
LT1206CR#PBF
LT1206CR(SMD)
КорпусDDPAK-7
Код корпусаR
Индекс корпуса05-08-1462
Количество каналов1
Частота единичного усиления GBW66 МГц
Av Min Stable1 V/V
CMRR62 дБ
Cload10000 пФ
Design ToolsLTspice Model
Enoise 1/f Corner60 Hz
Enoise Density3.6 нВ/rtГц
Экспортный контрольнет
Inoise2 пА/rtГц
Inoise 1/f Corner100 Hz
Iout500 мА
Isupply20 мА
Over-the-Topнет
PSRR77 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR900 В/мс
Shutdownда
Single Supplyнет
ТипCFA
VinCM High (from V+)1.5 В
VinCM Low (from V-)1.5 В
Voh (from V+)1.5 В
Vol (from V-)1.4 В
Vos3 мВ
Vos TC10 мВ/C
Vs макс.36 В
Vs мин.10 В
  • Video Circuit Collection &mdash AN57
    PDF, 559 Кб, Файл опубликован: 2 янв 1994
    AN57, the Video Circuit Collection, features a variety of video circuits designed at LTC. The LT1204 70MHz multiplexer is featured in a number of circuits which require excellent video isolation from channel to channel. High speed voltage and current feedback amplifiers are highlighted throughout the section on video processing circuits. There is a section on applying Current Feedback Amplifiers (CFAs) and a number of articles taken from the Linear Technology magazine.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
Design Notes
  • Fast Current Feedback Amplifiers Tame Low Impedance Loads &mdash DN132
    PDF, 91 Кб, Файл опубликован: 1 июл 1996
  • C-Load TM Op Amps Tame Instabilities &mdash DN83
    PDF, 929 Кб, Файл опубликован: 1 июн 1994
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Low Noise Amplifiers ( | High Output Current Amplifiers (>100mA) | High Voltage Amplifiers (>12V) | Current Feedback Amplifiers
LT1206CRPBF, LT1206CR PBF
На английском языке: Datasheet Linear Technology LT1206CR#PBF
Публикации по теме
