Линейка продуктов KEEN SIDE
Datasheet Linear Technology LT1220CS8#TRPBF — Даташит
СерияLT1220
МодельLT1220CS8#TRPBF
Операционный усилитель 45 МГц, 250 В / мкс
Datasheet LT1220
PDF, 273 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 12
45MHz, 250V/µs Operational Amplifier
22 предложений от 9 поставщиков
LT1220CS8#TRPBF
245 ₽
LT1220CS8#TRPBF
247 ₽
LT1220CS8#TRPBF
766 ₽
LT1220CS8 TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW45 МГц
Av Min Stable1 V/V
CMRR114 дБ
Cload100000 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise 1/f Corner800 Hz
Enoise Density17 нВ/rtГц
Экспортный контрольнет
Ibias100 нА
Inoise2 пА/rtГц
Inoise 1/f Corner800 Hz
Iout26 мА
Isupply8 мА
Over-the-Topнет
PSRR94 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR250 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)75 нс
ТипVFB
VinCM Low (from V-)3 В
Voh (from V+)2 В
Vol (from V-)2 В
Vos0.5 мВ
Vos TC20 мВ/C
Vs макс.36 В
Vs мин.5 В
  • An Introduction to Acoustic Thermometry &mdash AN131
    PDF, 456 Кб, Файл опубликован: 26 апр 2011
    Acoustic thermometry is an arcane, elegant temperature measurement technique. It utilizes sound's temperature dependent transit time in a medium to measure temperature. The medium may be a solid, liquid or gas. Acoustic thermometers function in environments that conventional sensors cannot tolerate. Examples include extreme temperatures, applications where the sensor would be subjected to destructive physical abuse and nuclear reactors. This application note describes theory, practical acoustic thermometer circuitry and transducer construction details. Two appended sections cover calibration and present a complete software listing.
  • High Speed Amplifier Techniques &mdash AN47
    PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
    This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.
  • Video Circuit Collection &mdash AN57
    PDF, 559 Кб, Файл опубликован: 2 янв 1994
    AN57, the Video Circuit Collection, features a variety of video circuits designed at LTC. The LT1204 70MHz multiplexer is featured in a number of circuits which require excellent video isolation from channel to channel. High speed voltage and current feedback amplifiers are highlighted throughout the section on video processing circuits. There is a section on applying Current Feedback Amplifiers (CFAs) and a number of articles taken from the Linear Technology magazine.
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
Design Notes
  • C-Load TM Op Amps Conquer Instabilities &mdash DN107
    PDF, 495 Кб, Файл опубликован: 1 июл 1995
  • Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140
    PDF, 74 Кб, Файл опубликован: 1 окт 1996
  • Current Feedback Amplifier Do's and Don'ts &mdash DN46
    PDF, 167 Кб, Файл опубликован: 1 апр 1991
  • High Frequency Amplifier Evaluation Board &mdash DN50
    PDF, 121 Кб, Файл опубликован: 1 янв 1991
  • C-Load TM Op Amps Tame Instabilities &mdash DN83
    PDF, 929 Кб, Файл опубликован: 1 июн 1994
Серия: LT1220 (3)
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > General Purpose Amplifiers | High Voltage Amplifiers (>12V)
LT1220CS8TRPBF, LT1220CS8 TRPBF
На английском языке: Datasheet Linear Technology LT1220CS8#TRPBF
Публикации по теме
