Datasheet Linear Technology LT1222CS8#TRPBF — Даташит
СерияLT1222
МодельLT1222CS8#TRPBF
Операционный усилитель AV >=10, 500 МГц, 3 нВ/rtГц
Datasheet LT1222
PDF, 262 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 12
500MHz, 3nV/√Hz, AV ≥ 10 Operational Amplifier
33 предложений от 14 поставщиков
LT1222CS8#TRPBF
от 178 ₽
LT1222CS8#TRPBF
255 ₽
Эиком
LT1222CS8#TRPBF
от 1 236 ₽
LT1222CS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов1
Частота единичного усиления GBW500 МГц
Av Min Stable10 V/V
Avol46 дБ
CMRR120 дБ
Cload1000 пФ
Demo BoardsDC1416B,DC417B
Design ToolsLTspice Model
Enoise 1/f Corner110 Hz
Enoise Density3 нВ/rtГц
Экспортный контрольнет
Ibias100 нА
Inoise2 пА/rtГц
Inoise 1/f Corner150 Hz
Ios0.0001 мкА
Iout26 мА
Isupply8 мА
Over-the-Topнет
PSRR110 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR200 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)75 нс
ТипVFB
VinCM High (from V+)3 В
VinCM Low (from V-)3 В
Voh (from V+)2 В
Vol (from V-)2 В
Vos0.1 мВ
Vos TC5 мВ/C
Vs макс.36 В
Vs мин.5 В
  • High Speed Amplifier Techniques &mdash AN47
    PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
    This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
Design Notes
  • Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140
    PDF, 74 Кб, Файл опубликован: 1 окт 1996
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Low Noise Amplifiers ( | High Voltage Amplifiers (>12V)
LT1222CS8TRPBF, LT1222CS8 TRPBF
На английском языке: Datasheet Linear Technology LT1222CS8#TRPBF
Публикации по теме
