Datasheet Linear Technology LT1366CN8#PBF — Даташит
СерияLT1366
МодельLT1366CN8#PBF
Двойные прецизионные линейные входные и выходные операционные усилители
Datasheet LT1366, LT1367, LT1368, LT1369
PDF, 396 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 20
Dual and Quad Precision Rail-to-Rail Input and Output Op Amps
43 предложений от 21 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1366CN8#PBF Operational Amplifier, Dual, 2 Amplifier, 400kHz, 0.13V/µs, 1.8V to ± 15V, DIP, 8Pins
LT1366CN8#PBF
от 155 ₽
Зенер
Россия и страны ТС
LT1366CN8#PBF
от 527 ₽
Эиком
LT1366CN8#PBF
от 1 287 ₽
МосЧип
LT1366CN8#PBF
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Количество каналов2
Частота единичного усиления GBW0.4 МГц
Av Min Stable1 V/V
Avol66 дБ
CMRR106 дБ
Cload1000 пФ
Design ToolsLTspice Model
Enoise 1/f Corner1 Hz
Enoise Density29 нВ/rtГц
Экспортный контрольнет
Ibias10 нА
Inoise0.07 пА/rtГц
Inoise 1/f Corner3.5 Hz
Ios0.001 мкА
Iout75 мА
Isupply0.34 мА
Over-the-Topнет
PSRR105 дБ
Rail-to-RailBoth
Rail-to-Rail Inда
Rail-to-Rail Outда
SR0.13 В/мс
Shutdownнет
Single Supplyда
Ts (0.1%)30000 нс
ТипVFB
Voh (from V+)0.004 В
Vol (from V-)0.006 В
Vos0.15 мВ
Vos TC2 мВ/C
Vs макс.36 В
Vs мин.2 В
LT1367 LT1367 LT1368 LT1368 LT1369 LT1369
  • Linear Technology Magazine Circuit Collection, Volume II &mdash AN66
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
    Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • A Versatile 8-Channel Multiplexer &mdash DN112
    PDF, 75 Кб, Файл опубликован: 1 сен 1995
  • LTC1392 Monitors System Temperature and Multiple Supply Voltages and Currents &mdash DN149
    PDF, 70 Кб, Файл опубликован: 1 мар 1997
  • Applications of a Rail-to-Rail Amplifier &mdash DN89
    PDF, 77 Кб, Файл опубликован: 1 окт 1994
Серия: LT1366 (3)
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Power Amplifiers (Is < 1mA/amp) | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
LT1366CN8PBF, LT1366CN8 PBF
На английском языке: Datasheet Linear Technology LT1366CN8#PBF
Публикации по теме
