Datasheet Linear Technology LT1635IS8#TRPBF — Даташит
СерияLT1635
МодельLT1635IS8#TRPBF
Micro-Power Rail-to-Rail Op Amp и эталон
Datasheet LT1635
PDF, 242 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 12
Micropower Rail-to-Rail Op Amp and Reference
Микросхема Буферный усилитель, IC OPAMP GP 175kHz RRO 8SO
LT1635IS8#TRPBF
164 ₽
LT1635IS8#TRPBF
339 ₽
LT1635IS8#TRPBF
LT1635IS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Demo BoardsDC417B
Design ToolsLTspice Model
Экспортный контрольнет
Initial Accuracy2.5 %
Min Vin/Vout DifferentialShunt В
Quiescent or Min Shunt Current130 мкА
Ref Vout0.2 В
Series/ShuntShunt
Temp Co30 ppm/В°C
Vin Max14 В
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84
    PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
    Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.
  • Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90
    PDF, 409 Кб, Файл опубликован: 1 апр 2002
    A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | Low Power Amplifiers (Is < 1mA/amp) | Rail-to-Rail Amplifiers
  • Signal Conditioning > Voltage References > Reference Plus Comparator or Amplifier
LT1635IS8TRPBF, LT1635IS8 TRPBF
На английском языке: Datasheet Linear Technology LT1635IS8#TRPBF
