Datasheet Linear Technology LT1818IS5#PBF — Даташит
СерияLT1818
МодельLT1818IS5#PBF
400MHz, 2500V/Ојs, 9mA Single Operational Amplifiers
Datasheet LT1818, LT1819
PDF, 1.2 Мб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 18
400MHz, 2500V/μs, 9mA Single Operational Amplifiers
39 предложений от 19 поставщиков
Рутоника
LT1818IS5#TRPBF
121 ₽
LT1818IS5#TRPBF
261 ₽
LT1818IS5#TRMPBF
LT1818IS5#TRPBF
КорпусSOT-23
Код корпусаS5
Индекс корпуса05-08-1635
Количество каналов1
Частота единичного усиления GBW400 МГц
Av Min Stable1 V/V
Avol8 дБ
CMRR85 дБ
Cload20 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise 1/f Corner110 Hz
Enoise Density6 нВ/rtГц
Экспортный контрольнет
Ibias2000 нА
Inoise1.2 пА/rtГц
Inoise 1/f Corner140 Hz
Ios0.06 мкА
Iout70 мА
Isupply9 мА
Over-the-Topнет
PSRR97 дБ
Rail-to-Rail Inнет
Rail-to-Rail Outнет
SR2500 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)10 нс
ТипVFB
VinCM High (from V+)0.8 В
VinCM Low (from V-)0.8 В
Voh (from V+)0.9 В
Vol (from V-)0.9 В
Vos0.2 мВ
Vos TC10 мВ/C
Vs макс.12.6 В
Vs мин.3.5 В
LT1819 LT1819
  • 2 Nanosecond, .1% Resolution Settling Time Measurement for Wideband Amplifiers &mdash AN128
    PDF, 1.1 Мб, Файл опубликован: 16 авг 2010
    Instrumentation, waveform synthesis, data acquisition, feedback control systems and other application areas utilize wideband amplifiers. Current generation components feature good DC precision while maintaining high speed operation. Verifying precision operation at high speed is essential, and presents a high order measurement challenge.
  • Slew Rate Verification for Wideband Amplifiers: The Taming of the Slew &mdash AN94
    PDF, 594 Кб, Файл опубликован: 1 май 2003
    Wideband amplifiers achieve slew rates beyond 2500V/µs. Verifying slew rates at this speed requires special techniques. In particular, a subnanosecond rise time input step is necessary for accurate slew rate measurement. A pulse generator with a 360 picosecond rise time is shown, and its construction detailed. Slew rate test results using this generator are presented and compared to data taken with slower rise time generators. Appendices cover high speed measurement technique, generator output level shifting and picosecond signal path construction considerations.
Статьи
  • 2500V/µs Slew Rate Op Amps Process Large Signals with Low Distortion at High Frequencies &mdash LT Journal
    PDF, 388 Кб, Файл опубликован: 1 дек 2002
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | High Voltage Amplifiers (>12V) | Low Noise Amplifiers (
LT1818IS5PBF, LT1818IS5 PBF
На английском языке: Datasheet Linear Technology LT1818IS5#PBF
Публикации по теме
