Datasheet Linear Technology LT1884ACS8#TRPBF — Даташит
СерияLT1884
МодельLT1884ACS8#TRPBF
Двойной / четырехъядерный рельсовый выход, точные операционные усилители Picoamp
Datasheet LT1884, LT1885
PDF, 173 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 12
Dual/Quad Rail-to-Rail Output, Picoamp Input Precision Op Amps
IC OPAMP GP 2 CIRCUIT 8SO. General Purpose Amplifier 2 Circuit Rail-to-Rail 8-SO. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
LT1884ACS8#TRPBF
371 ₽
LT1884ACS8#TRPBF
411 ₽
727GS
LT1884ACS8#TRPBF
SUV System
LT1884ACS8#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Количество каналов2
Частота единичного усиления GBW2 МГц
Av Min Stable1 V/V
Avol64 дБ
CMRR128 дБ
Cload500 пФ
Design ToolsLTspice Model
Enoise 1/f Corner2.5 Hz
Enoise Density9.5 нВ/rtГц
Экспортный контрольнет
Ibias0.1 нА
Inoise0.05 пА/rtГц
Inoise 1/f Corner14 Hz
Ios0.0001 мкА
Iout30 мА
Isupply0.65 мА
LF Enoise0.4 µVPP
Over-the-Topнет
PSRR132 дБ
Rail-to-RailOutput
Rail-to-Rail Inнет
Rail-to-Rail Outда
SR0.9 В/мс
Shutdownнет
Single Supplyнет
Ts (0.1%)10000 нс
ТипVFB
VinCM High (from V+)1 В
VinCM Low (from V-)1 В
Voh (from V+)0.12 В
Vol (from V-)0.02 В
Vos0.025 мВ
Vos TC0.3 мВ/C
Vs макс.40 В
Vs мин.2.4 В
LT1885 LT1885
  • Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98
    PDF, 886 Кб, Файл опубликован: 19 ноя 2004
    Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.
Design Notes
  • Rail-to-Rail Amplifiers Operate on 2.7V with 20ВµV Offset &mdash DN230
    PDF, 75 Кб, Файл опубликован: 15 апр 2001
Статьи
  • New Rail-to-Rail Output Op Amps Bring Precision Performance to Low Voltage Systems &mdash LT Journal
    PDF, 370 Кб, Файл опубликован: 1 май 2000
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Rail-to-Rail Amplifiers | Precision Amplifiers (Vos | Low Power Amplifiers (Is < 1mA/amp) | High Voltage Amplifiers (>12V) | Low Bias Current Amplifiers (Ib < 100pA)
LT1884ACS8TRPBF, LT1884ACS8 TRPBF
На английском языке: Datasheet Linear Technology LT1884ACS8#TRPBF
