Datasheet Linear Technology LT1712CGN#PBF — Даташит
| Серия | LT1712 |
| Модель | LT1712CGN#PBF |
Двойные 4,5 нс компараторы Rail-to-Rail
Datasheet LT1711, LT1712
PDF, 226 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 12
Single/Dual 4.5ns, 3V/5V/±5V, Rail-to-Rail Comparators
Купить LT1712CGN#PBF на РадиоЛоцман.Цены — от 146 до 1 329 ₽36 предложений от 22 поставщиков IC COMP R-R I/O DUAL LP 16SSOP. Comparator with Latch CMOS, Complementary, Rail-to-Rail, TTL 16-SSOP. Linear - Comparators | |||
| LT1712CGN Analog Devices | 771 ₽ | ||
| LT1712CGN#PBF Analog Devices | 1 135 ₽ | ||
| LT1712CGN#PBF Linear Technology | по запросу | ||
| LT1712CGN#PBF Analog Devices | по запросу | ||
| Корпус | SSOP-16 |
| Код корпуса | GN |
| Индекс корпуса | 05-08-1641 (GN16) |
| Количество каналов | 2 |
| Design Tools | LTspice Model |
| Экспортный контроль | нет |
| Основные особенности | Rail-to-Rail In/Out, Output Latch |
| Hysteresis | None |
| Isupply | 10 мА |
| Рабочий диапазон температур | от 0 до 70 °C |
| Output Rise/Fall Time | 2, 2 нс |
| Prop Delay | 0.0045 µs |
| Separate O/P Supply | None |
| Диапазон напряжения питания | 2.4V to 12V/В±2.4V to В±6V |
| Vos | 0.5 мВ |
| Vs макс. | 12 В |
| Vs мин. | 2.4 В |
- Minimizing Switching Regulator Residue in Linear Regulator Outputs &mdash AN101PDF, 358 Кб, Язык: анг., Файл опубликован: 16 июл 2005, Страниц: 12
Application Note 101. Linear regulators are commonly employed to post-regulate switching regulator outputs. Benefits include improved stability, accuracy, transient response and lowered output impedance. Ideally, these performance gains would be accompanied by markedly reduced switching regulator generated ripple and spikes. In practice, all linear regulators encounter some difficulty with ripple and spikes, particularly as frequency rises. This publication explains the causes of linear regulators' dynamic limitations and presents board level techniques for improving ripple and spike rejection. A hardware based ripple/spike simulator is presented, enabling rapid breadboard testing under various conditions. Three appendices review ferrite beads, inductor based filters and probing practice for wideband, sub-millivolt signals.Выписка из документа
Design Notes
- Rail-to-Rail I/O and 2.4V Operation Allow UltraFast Comparators to be Used on Low Voltage Supplies &mdash DN248PDF, 105 Кб, Файл опубликован: 1 янв 2001Выписка из документа
Статьи
- New UltraFast Comparators: Rail-to-Rail Inputs and 2.4V Operation Allow Use on Low Supplies &mdash LT JournalPDF, 194 Кб, Файл опубликован: 1 фев 2001Выписка из документа
Серия: LT1712 (4)
- LT1712CGN#PBF LT1712CGN#TRPBF LT1712IGN#PBF LT1712IGN#TRPBF
- Signal Conditioning > Comparators > High Speed Comparators
LT1712CGNPBF, LT1712CGN PBF
