Datasheet Linear Technology LT1721IS#TRPBF — Даташит
Серия | LT1721 |
Модель | LT1721IS#TRPBF |
Четырехканальные, 4,5 нс, однополярные компараторы 3 В / 5 В с выходами Rail-to-Rail
Datasheet LT1720, LT1721
PDF, 274 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 28
Dual/Quad, 4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs
8 предложений от 8 поставщиков Микросхема Компаратор, Comparator Quad R-R O/P 6V 16Pin SOIC N T/R | |||
LT1721IS#TRPBF Analog Devices | 333 ₽ | ||
LT1721IS#TRPBF Analog Devices | по запросу | ||
LT1721IS#TRPBF | по запросу |
Корпус | SO-16 |
Код корпуса | S |
Индекс корпуса | 05-08-1610 (S16) |
Количество каналов | 4 |
Design Tools | LTspice File |
Экспортный контроль | нет |
Основные особенности | Rail-to-Rail Out |
Hysteresis | None |
Isupply | 4 мА |
Output Rise/Fall Time | 2.5, 2.2 нс |
Prop Delay | 0.0045 µs |
Separate O/P Supply | None |
Диапазон напряжения питания | 2.7V to 6V |
Vos | 1 мВ |
Vs макс. | 6 В |
Vs мин. | 2.7 В |
- Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98PDF, 886 Кб, Файл опубликован: 19 ноя 2004
Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.Выписка из документа
Серия: LT1721 (8)
- Signal Conditioning > Comparators > High Speed Comparators
LT1721ISTRPBF, LT1721IS TRPBF
