Datasheet Linear Technology LTC1562IG#TRPBF — Даташит
СерияLTC1562
МодельLTC1562IG#TRPBF
Универсальный фильтр Active RC Quad с очень низким уровнем шума и искажений
LTC1562 - Very Low Noise, Low Distortion Active RC Quad Universal Filter
PDF, 354 Кб, Версия: A, Файл закачен: 9 авг 2017
30 предложений от 17 поставщиков
IC FILTER UNIV RC QUAD LN 20SSOP / Active Filter Quad Continuous Time UNIV 8th Order 300kHz 20-Pin SSOP T/R
LTC1562IG#TRPBF
928 ₽
LTC1562IG#TRPBF
1 185 ₽
Зенер
Россия и страны ТС
LTC1562IG-2#TRPBF
от 3 494 ₽
LTC1562IG TRPBF
КорпусSSOP-20
Код корпусаG
Индекс корпуса05-08-1640 (G20)
Clock Tunableнет
Demo BoardsDC266B-B
Design ToolsLTspice Model
Экспортный контрольнет
Filter Order8 order
Filters Per Package4
Fo Max150 kHz
Fo Min10 kHz
Fo/FclkN/A
Isupply18 мА
PreconfiguredUniversal
Vs макс.10 В
Vs мин.4.75 В
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash AN83
    PDF, 542 Кб, Файл опубликован: 1 мар 2000
    In an increasing trend, telecommunications, networking, audio and instrumentation require low noise power supplies. In particular, there is interest in low noise, low dropout linear regulators (LDO). Establishing and specifying LDO dropout performance is relatively easy to do. Verifying that a regulator meets dropout specification is similarly straightforward. Accomplishing the same missions for noise and noise testing is considerably more involved. The noise bandwidth of interest must be called out, along with operating conditions. Low noise performance is affected by numerous subtleties; changes in operating conditions can cause unwelcome surprises. Because of this, LDO noise must be quoted under specified operating and bandwidth conditions to be meaningful. Failure to observe this precaution results in misleading data and erroneous conclusions. This Application Note suggests a noise testing method, details its implementation and presents results.
Design Notes
  • Get 100dB Stopband Attenuation with the LTC1562 Universal Filter Family &mdash DN195
    PDF, 333 Кб, Файл опубликован: 1 дек 1998
Статьи
  • Universal Continuous-Time Filter Challenges Discrete Designs &mdash LT Journal
    PDF, 291 Кб, Файл опубликован: 1 фев 1998
  • How to Design High Order Filters with Stopband Notches Using the LTC1562 Operational Filter (Part 2) &mdash LT Journal
    PDF, 87 Кб, Файл опубликован: 1 фев 1999
  • New Universal Continuous-Time Filter with Extended Frequency Range &mdash LT Journal
  • How to Design High Order Filters with Stopband Notches Using the LTC1562 Quad Operational Filter (Part 1) &mdash LT Journal
    PDF, 293 Кб, Файл опубликован: 1 май 1998
  • Sharp Gain Roll-Offs Using the LTC1562 Quad Operational Filter IC (Part 3) &mdash LT Journal
    PDF, 178 Кб, Файл опубликован: 1 ноя 1999
  • Performance Verification of Low Noise, Low Dropout Regulators &mdash LT Journal
    PDF, 1.2 Мб, Файл опубликован: 1 сен 2000
  • Signal Conditioning > Filters > Filter Building Blocks
LTC1562IGTRPBF, LTC1562IG TRPBF
На английском языке: Datasheet Linear Technology LTC1562IG#TRPBF
