Datasheet Linear Technology LTC1164-7CSW#TRPBF — Даташит
СерияLTC1164-7
МодельLTC1164-7CSW#TRPBF
Маломощный линейный фильтр нижних частот 8-го порядка
LTC1164-7 - Low Power, Linear Phase 8th Order Lowpass Filter
PDF, 268 Кб, Версия: B, Файл закачен: 9 авг 2017
LTC1164-7CSW TRPBF
КорпусSW-16
Код корпусаSW
Индекс корпуса05-08-1620 (SW16)
Clock Tunableда
Экспортный контрольнет
Filter Order8 order
Filters Per Package1
Fo Max20 kHz
Fo Min1 kHz
Fo/Fclk100, 50:1
Isupply2.5 мА
PreconfiguredLowpass
Vs макс.16 В
Vs мин.4.75 В
  • Better than Bessel Linear Phase Filters For Data Communications &mdash AN56
    PDF, 311 Кб, Файл опубликован: 1 янв 1994
    The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.
Серия: LTC1164-7 (3)
  • Signal Conditioning > Filters > Lowpass Filters
LTC1164-7CSWTRPBF, LTC1164-7CSW TRPBF, LTC11647CSW#TRPBF, LTC1164 7CSW#TRPBF
На английском языке: Datasheet Linear Technology LTC1164-7CSW#TRPBF
Публикации по теме
