Datasheet Linear Technology LTC1164-7 — Даташит
СерияLTC1164-7
Маломощный линейный фильтр нижних частот 8-го порядка
LTC1164-7 - Low Power, Linear Phase 8th Order Lowpass Filter
PDF, 268 Кб, Версия: B, Файл закачен: 9 авг 2017
28 предложений от 25 поставщиков
Linear Phase, Low Pass Switched Capacitor Filter IC Linear Phase, Low Pass Switched Capacitor 8th Order 100kHz 14-PDIP
LTC1164-7CN#PBF
1 532 ₽
Элитан
LTC1164-7CSW
6 274 ₽
МосЧип
LTC1164-7CSW#PBF
ТаймЧипс
LTC1164-7CN#PBF
LTC1164-7CN#PBFLTC1164-7CSW#PBFLTC1164-7CSW#TRPBF
N123
КорпусN-14
Габаритный чертеж корпуса
SW-16
SW-16
Код корпусаNSWSW
Индекс корпуса05-08-1510 (N14)05-08-1620 (SW16)05-08-1620 (SW16)
Количество выводов141616
Parameters / ModelsLTC1164-7CN#PBFLTC1164-7CSW#PBFLTC1164-7CSW#TRPBF
Clock Tunableдадада
Экспортный контрольнетнетнет
Filter Order, order888
Filters Per Package111
Fo Max, kHz202020
Fo Min, kHz111
Fo/Fclk100, 50:1100, 50:1100, 50:1
Isupply, мА2.52.52.5
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70
PreconfiguredLowpassLowpassLowpass
Vs макс., В161616
Vs мин., В4.754.754.75
  • Better than Bessel Linear Phase Filters For Data Communications &mdash AN56
    PDF, 311 Кб, Файл опубликован: 1 янв 1994
    The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.
  • Signal Conditioning > Filters > Lowpass Filters
На английском языке: Datasheet Linear Technology LTC1164-7
Публикации по теме
