Линейка продуктов KEEN SIDE
Datasheet Linear Technology LTC1059CS#PBF — Даташит
СерияLTC1059
МодельLTC1059CS#PBF
Высокопроизводительный универсальный фильтр с переключаемым конденсатором
LTC1059 - High Performance Switched Capacitor Universal Filter
PDF, 124 Кб, Версия: D, Файл закачен: 10 авг 2017
36 предложений от 22 поставщиков
Фильтр: цифровой; конденсаторный переключаемый; универсальный
727GS
LTC1059CS#PBF
от 170 ₽
LTC1059CS#PBF
176 ₽
Зенер
Россия и страны ТС
LTC1059CS#PBF
от 540 ₽
LTC1059CS#PBF
931 ₽
КорпусSO-14
Код корпусаS
Индекс корпуса05-08-1610 (S14)
Clock Tunableда
Экспортный контрольнет
Filter Order2 order
Filters Per Package1
Fo Max40 kHz
Fo Min1 kHz
Fo/Fclk100, 50:1
Isupply1.5 мА
PreconfiguredUniversal
Vs макс.16 В
Vs мин.4.75 В
  • Unique Applications for the LTC1062 Lowpass Filter &mdash AN24
    PDF, 587 Кб, Файл опубликован: 1 сен 1987
    Highlights the LTC1062 as a lowpass filter in a phase lock loop. Describes how the loop's bandwidth can be increased and the VCO output jitter reduced when the LTC1062 is the loop filter. Compares it with a passive RC loop filter. Also discussed is the use of LTC1062 as simple bandpass and bandstop filter.
  • A Simple Method of Designing Order All Pole Bandpass Filters by Cascading 2nd Order Sections &mdash AN27A
    PDF, 245 Кб, Файл опубликован: 23 июн 1988
    Presents two methods of designing high quality switched capacitor bandpass filters. Both methods are intended to vastly simplify the mathematics involved in filter design by using tabular methods. The text assumed no filter design experience but allows high quality filters to be implemented by techniques not presented before in the literature. The designs are implemented by numerous examples using devices from LTC's Switched- Capacitor filter family: LTC1060, LTC1061, and LTC1064. Butterworth and Chebyshev bandpass filters are discussed.
Серия: LTC1059 (3)
  • Signal Conditioning > Filters > Filter Building Blocks
LTC1059CSPBF, LTC1059CS PBF
На английском языке: Datasheet Linear Technology LTC1059CS#PBF
