Datasheet Linear Technology LTC1060ACN#PBF — Даташит
СерияLTC1060
МодельLTC1060ACN#PBF
Универсальный блок с двойным фильтром
LTC1060 - Universal Dual Filter Building Block
PDF, 270 Кб, Версия: B, Файл закачен: 10 авг 2017
36 предложений от 19 поставщиков
IC FILTER 30KHZ UNIV SWTCH 20DIP. Universal Switched Capacitor Filter IC Universal Switched Capacitor 4th Order 30kHz 20-PDIP. Interface - Filters...
LTC1060ACN#PBF
1 613 ₽
LTC1060ACN#PBF
от 2 502 ₽
Hi-Tech Circuit Group
LTC1060ACN#PBF
SUV System
LTC1060ACN#PBF
КорпусN-20
Код корпусаN
Индекс корпуса05-08-1510 (N20)
Clock Tunableда
Design ToolsLTspice Model
Экспортный контрольнет
Filter Order4 order
Filters Per Package2
Fo Max20 kHz
Fo Min1 kHz
Fo/Fclk100, 50:1
Isupply2.5 мА
PreconfiguredUniversal
Vs макс.16 В
Vs мин.4.75 В
  • Unique Applications for the LTC1062 Lowpass Filter &mdash AN24
    PDF, 587 Кб, Файл опубликован: 1 сен 1987
    Highlights the LTC1062 as a lowpass filter in a phase lock loop. Describes how the loop's bandwidth can be increased and the VCO output jitter reduced when the LTC1062 is the loop filter. Compares it with a passive RC loop filter. Also discussed is the use of LTC1062 as simple bandpass and bandstop filter.
  • A Simple Method of Designing Order All Pole Bandpass Filters by Cascading 2nd Order Sections &mdash AN27A
    PDF, 245 Кб, Файл опубликован: 23 июн 1988
    Presents two methods of designing high quality switched capacitor bandpass filters. Both methods are intended to vastly simplify the mathematics involved in filter design by using tabular methods. The text assumed no filter design experience but allows high quality filters to be implemented by techniques not presented before in the literature. The designs are implemented by numerous examples using devices from LTC's Switched- Capacitor filter family: LTC1060, LTC1061, and LTC1064. Butterworth and Chebyshev bandpass filters are discussed.
  • Take the Mystery Out of the Switched Capacitor Filter &mdash AN40
    PDF, 3.0 Мб, Файл опубликован: 1 мар 1990
    This note presents guidelines for circuits utilizing LTC's switched capacitor filters. The discussion focuses on how to optimize filter performance by optimizing the printed wiring board, the power supply, and the output buffering of the filter. Many additional topics are discussed such as how to select the proper filter response for the application and how to characterize a filter's THD for DSP applications.
  • Signal Conditioning > Filters > Filter Building Blocks
LTC1060ACNPBF, LTC1060ACN PBF
На английском языке: Datasheet Linear Technology LTC1060ACN#PBF
