Datasheet Linear Technology LTC1062CN8#PBF — Даташит
СерияLTC1062
МодельLTC1062CN8#PBF
Фильтр нижних частот 5-го порядка
LTC1062 - 5th Order Lowpass Filter
PDF, 201 Кб, Версия: D, Файл закачен: 10 авг 2017
38 предложений от 18 поставщиков
Активный фильтр , Active Filter Single SW-CAP Low Pass 5th Order 20kHz 8Pin PDIP N
LTC1062CN8#PBF
212 ₽
LTC1062CN8#PBF
827 ₽
Эиком
LTC1062CN8
от 1 061 ₽
ЗУМ-СМД
LTC1062CN8#PBF
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Clock Tunableда
Экспортный контрольнет
Filter Order5 order
Filters Per Package1
Fo Max20 kHz
Fo Min1 kHz
Fo/Fclk100:1
Isupply4.5 мА
PreconfiguredLowpass
Vs макс.18 В
Vs мин.4.75 В
  • Application Considerations for an Instrumentation Lowpass Filter &mdash AN20
    PDF, 2.8 Мб, Файл опубликован: 1 сен 1986
    Discusses the principles of operation of the LTC1062 and helpful hints for its application. Various application circuits are explained in detail with focus on how to cascade two LTC1062s and how to obtain notches. Noise and distortion performance are fully illustrated.
  • Unique Applications for the LTC1062 Lowpass Filter &mdash AN24
    PDF, 587 Кб, Файл опубликован: 1 сен 1987
    Highlights the LTC1062 as a lowpass filter in a phase lock loop. Describes how the loop's bandwidth can be increased and the VCO output jitter reduced when the LTC1062 is the loop filter. Compares it with a passive RC loop filter. Also discussed is the use of LTC1062 as simple bandpass and bandstop filter.
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Instrumentation Applications for a Monolithic Oscillator: A Clock for All Reasons &mdash AN93
    PDF, 1.1 Мб, Файл опубликован: 1 фев 2003
    Instrumentation applications for a monolithic programmable oscillator are presented in this publication. Circuits include platinum and thermistor based thermometers, an isolated thermometer and three relative humidity signal conditioners. Bipolar and FET input chopper stabilized amplifiers with noise below 45nV (0.1Hz to 10Hz) are detailed. Two clock tunable sine wave generators with settable amplitude appear, as well as a tunable notch filter, an interval generator and an A to D converter. The oscillator's performance is contrasted against other approaches and its interval operation discussed.
Design Notes
  • Sampling of Signals for Digital Filtering and Gated Measurements &mdash DN2
    PDF, 377 Кб, Файл опубликован: 1 окт 1987
  • Complex Data Acquisition System Uses Few Components &mdash DN24
    PDF, 84 Кб, Файл опубликован: 1 июл 1989
  • DC Accurate Filter Eases PLL Design &mdash DN7
    PDF, 203 Кб, Файл опубликован: 1 фев 1988
  • Chopper Amplifiers Complement a DC Accurate Low-Pass Filter &mdash DN9
    PDF, 369 Кб, Файл опубликован: 1 мар 1988
Серия: LTC1062 (3)
  • Signal Conditioning > Filters > Lowpass Filters
LTC1062CN8PBF, LTC1062CN8 PBF
На английском языке: Datasheet Linear Technology LTC1062CN8#PBF
