Datasheet Linear Technology LTC1064-1CSW#TRPBF — Даташит
| Серия | LTC1064-1 |
| Модель | LTC1064-1CSW#TRPBF |
Малошумящий эллиптический фильтр нижних частот 8-го порядка с тактовой частотой и возможностью изменения частоты
LTC1064-1 - Low Noise, 8th Order, Clock Sweepable Elliptic Lowpass Filter
PDF, 180 Кб, Версия: A, Файл закачен: 10 авг 2017
| LTC1064-1CSW TRPBF Linear Technology | по запросу | ||
| Корпус | SW-16 |
| Код корпуса | SW |
| Индекс корпуса | 05-08-1620 (SW16) |
| Clock Tunable | да |
| Экспортный контроль | нет |
| Filter Order | 8 order |
| Filters Per Package | 1 |
| Fo Max | 50 kHz |
| Fo Min | 1 kHz |
| Fo/Fclk | 100:1 |
| Isupply | 10 мА |
| Рабочий диапазон температур | от 0 до 70 °C |
| Preconfigured | Lowpass |
| Vs макс. | 16 В |
| Vs мин. | 4.75 В |
- Take the Mystery Out of the Switched Capacitor Filter &mdash AN40PDF, 3.0 Мб, Файл опубликован: 1 мар 1990
This note presents guidelines for circuits utilizing LTC's switched capacitor filters. The discussion focuses on how to optimize filter performance by optimizing the printed wiring board, the power supply, and the output buffering of the filter. Many additional topics are discussed such as how to select the proper filter response for the application and how to characterize a filter's THD for DSP applications.Выписка из документа - Better than Bessel Linear Phase Filters For Data Communications &mdash AN56PDF, 311 Кб, Файл опубликован: 1 янв 1994
The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.Выписка из документа
Design Notes
- LTC1069-X: A New Family of 8th Order Monolithic Filters in an SO-8 Package &mdash DN147PDF, 84 Кб, Файл опубликован: 1 фев 1997Выписка из документа
- Switched-Capacitor Low Pass Filters for Anti-Aliasing Applications &mdash DN16PDF, 77 Кб, Файл опубликован: 1 окт 1988Выписка из документа
- Complex Data Acquisition System Uses Few Components &mdash DN24PDF, 84 Кб, Файл опубликован: 1 июл 1989Выписка из документа
- High Dynamic Range Bandpass Filters for Communications &mdash DN37PDF, 76 Кб, Файл опубликован: 1 июл 1990Выписка из документа
Серия: LTC1064-1 (4)
- LTC1064-1ACN#PBF LTC1064-1CN#PBF LTC1064-1CSW#PBF LTC1064-1CSW#TRPBF
- Signal Conditioning > Filters > Lowpass Filters
LTC1064-1CSWTRPBF, LTC1064-1CSW TRPBF, LTC10641CSW#TRPBF, LTC1064 1CSW#TRPBF
