Datasheet Linear Technology LTC1064-3CSW#PBF — Даташит
Серия | LTC1064-3 |
Модель | LTC1064-3CSW#PBF |
Малошумящий, высокочастотный, линейный фазовый фильтр нижних частот 8-го порядка
LTC1064-3 - Low Noise, High Frequency, 8th Order Linear Phase Lowpass Filter
PDF, 154 Кб, Версия: A, Файл закачен: 10 авг 2017
![]() 12 предложений от 12 поставщиков Low Noise, High Frequency, 8th Order Linear Phase Lowpass Filter | |||
LTC1064-3CSW Linear Technology | 920 ₽ | ||
LTC1064-3CSW Linear Technology | 931 ₽ | ||
LTC1064-3CSW/CS | по запросу | ||
LTC1064-3CSW. | по запросу |
Корпус | SW-16 |
Код корпуса | SW |
Индекс корпуса | 05-08-1620 (SW16) |
Clock Tunable | да |
Экспортный контроль | нет |
Filter Order | 8 order |
Filters Per Package | 1 |
Fo Max | 100 kHz |
Fo Min | 1 kHz |
Fo/Fclk | 150, 75:1 |
Isupply | 10 мА |
Рабочий диапазон температур | от 0 до 70 °C |
Preconfigured | Lowpass |
Vs макс. | 16 В |
Vs мин. | 4.75 В |
- Take the Mystery Out of the Switched Capacitor Filter &mdash AN40PDF, 3.0 Мб, Файл опубликован: 1 мар 1990
This note presents guidelines for circuits utilizing LTC's switched capacitor filters. The discussion focuses on how to optimize filter performance by optimizing the printed wiring board, the power supply, and the output buffering of the filter. Many additional topics are discussed such as how to select the proper filter response for the application and how to characterize a filter's THD for DSP applications.Выписка из документа - Better than Bessel Linear Phase Filters For Data Communications &mdash AN56PDF, 311 Кб, Файл опубликован: 1 янв 1994
The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.Выписка из документа
Серия: LTC1064-3 (3)
- LTC1064-3CN#PBF LTC1064-3CSW#PBF LTC1064-3CSW#TRPBF
- Signal Conditioning > Filters > Lowpass Filters
LTC1064-3CSWPBF, LTC1064-3CSW PBF, LTC10643CSW#PBF, LTC1064 3CSW#PBF
