Оптопары и оптореле Megawin
Datasheet Linear Technology LTC1064-3CSW#TRPBF — Даташит
СерияLTC1064-3
МодельLTC1064-3CSW#TRPBF
Малошумящий, высокочастотный, линейный фазовый фильтр нижних частот 8-го порядка
LTC1064-3 - Low Noise, High Frequency, 8th Order Linear Phase Lowpass Filter
PDF, 154 Кб, Версия: A, Файл закачен: 10 авг 2017
LTC1064-3CSW TRPBF
КорпусSW-16
Код корпусаSW
Индекс корпуса05-08-1620 (SW16)
Clock Tunableда
Экспортный контрольнет
Filter Order8 order
Filters Per Package1
Fo Max100 kHz
Fo Min1 kHz
Fo/Fclk150, 75:1
Isupply10 мА
PreconfiguredLowpass
Vs макс.16 В
Vs мин.4.75 В
  • Take the Mystery Out of the Switched Capacitor Filter &mdash AN40
    PDF, 3.0 Мб, Файл опубликован: 1 мар 1990
    This note presents guidelines for circuits utilizing LTC's switched capacitor filters. The discussion focuses on how to optimize filter performance by optimizing the printed wiring board, the power supply, and the output buffering of the filter. Many additional topics are discussed such as how to select the proper filter response for the application and how to characterize a filter's THD for DSP applications.
  • Better than Bessel Linear Phase Filters For Data Communications &mdash AN56
    PDF, 311 Кб, Файл опубликован: 1 янв 1994
    The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.
Серия: LTC1064-3 (3)
  • Signal Conditioning > Filters > Lowpass Filters
LTC1064-3CSWTRPBF, LTC1064-3CSW TRPBF, LTC10643CSW#TRPBF, LTC1064 3CSW#TRPBF
На английском языке: Datasheet Linear Technology LTC1064-3CSW#TRPBF
Публикации по теме
