Линейка продуктов KEEN SIDE
Datasheet Linear Technology LTC1064-3 — Даташит
СерияLTC1064-3
Малошумящий, высокочастотный, линейный фазовый фильтр нижних частот 8-го порядка
LTC1064-3 - Low Noise, High Frequency, 8th Order Linear Phase Lowpass Filter
PDF, 154 Кб, Версия: A, Файл закачен: 10 авг 2017
34 предложений от 25 поставщиков
Bessel, Low Pass Switched Capacitor Filter IC Bessel, Low Pass Switched Capacitor 8th Order 95kHz 14-PDIP
LTC1064-3CSW#TRPBF
543 ₽
LTC1064-3CN#PBF
551 ₽
Зенер
Россия и страны ТС
LTC1064-3CSW#PBF
от 3 389 ₽
Hi-Tech Circuit Group
LTC1064-3CSW#PBF
LTC1064-3CN#PBFLTC1064-3CSW#PBFLTC1064-3CSW#TRPBF
N123
КорпусN-14
Габаритный чертеж корпуса
SW-16
SW-16
Код корпусаNSWSW
Индекс корпуса05-08-1510 (N14)05-08-1620 (SW16)05-08-1620 (SW16)
Количество выводов141616
Parameters / ModelsLTC1064-3CN#PBFLTC1064-3CSW#PBFLTC1064-3CSW#TRPBF
Clock Tunableдадада
Экспортный контрольнетнетнет
Filter Order, order888
Filters Per Package111
Fo Max, kHz100100100
Fo Min, kHz111
Fo/Fclk150, 75:1150, 75:1150, 75:1
Isupply, мА101010
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70
PreconfiguredLowpassLowpassLowpass
Vs макс., В161616
Vs мин., В4.754.754.75
  • Take the Mystery Out of the Switched Capacitor Filter &mdash AN40
    PDF, 3.0 Мб, Файл опубликован: 1 мар 1990
    This note presents guidelines for circuits utilizing LTC's switched capacitor filters. The discussion focuses on how to optimize filter performance by optimizing the printed wiring board, the power supply, and the output buffering of the filter. Many additional topics are discussed such as how to select the proper filter response for the application and how to characterize a filter's THD for DSP applications.
  • Better than Bessel Linear Phase Filters For Data Communications &mdash AN56
    PDF, 311 Кб, Файл опубликован: 1 янв 1994
    The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.
  • Signal Conditioning > Filters > Lowpass Filters
На английском языке: Datasheet Linear Technology LTC1064-3
Публикации по теме
