Datasheet Linear Technology LTC1164ACSW#TRPBF — Даташит
СерияLTC1164
МодельLTC1164ACSW#TRPBF
Строительный блок четырехуниверсальных фильтров с низким энергопотреблением и низким уровнем шума
LTC1164 - Low Power, Low Noise, Quad Universal Filter Building Block
PDF, 214 Кб, Версия: A, Файл закачен: 10 авг 2017
IC FILTER 20KHZ SWITCHED 24SOIC. Universal Switched Capacitor Filter IC Universal Switched Capacitor 8th Order 20kHz 24-SOIC. Interface - Filters -...
LTC1164ACSW#TRPBF
1 625 ₽
LTC1164ACSW#TRPBF
2 451 ₽
LTC1164ACSW TRPBF
LTC1164ACSW#TRPBF
КорпусSW-24
Код корпусаSW
Индекс корпуса05-08-1620 (SW24)
Clock Tunableда
Экспортный контрольнет
Filter Order8 order
Filters Per Package4
Fo Max20 kHz
Fo Min1 kHz
Fo/Fclk100, 50:1
Isupply4 мА
PreconfiguredUniversal
Vs макс.16 В
Vs мин.4.75 В
  • Better than Bessel Linear Phase Filters For Data Communications &mdash AN56
    PDF, 311 Кб, Файл опубликован: 1 янв 1994
    The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.
  • Signal Conditioning > Filters > Filter Building Blocks
LTC1164ACSWTRPBF, LTC1164ACSW TRPBF
На английском языке: Datasheet Linear Technology LTC1164ACSW#TRPBF
