Datasheet Linear Technology LTC1164CN#PBF — Даташит
| Серия | LTC1164 |
| Модель | LTC1164CN#PBF |
Строительный блок четырехуниверсальных фильтров с низким энергопотреблением и низким уровнем шума
LTC1164 - Low Power, Low Noise, Quad Universal Filter Building Block
PDF, 214 Кб, Версия: A, Файл закачен: 10 авг 2017
 Купить LTC1164CN#PBF на РадиоЛоцман.Цены — от 395 до 2 993 ₽36 предложений от 19 поставщиков IC FILTER 20KHZ UNIV SWTCH 24DIP. Universal Switched Capacitor Filter IC Universal Switched Capacitor 8th Order 20kHz 24-PDIP. Interface - Filters...  | |||
| LTC1164CN#PBF Linear Technology  | 2 647 ₽ | ||
| LTC1164CN#PBF Analog Devices  | от 2 651 ₽ | ||
| LTC1164CN | по запросу | ||
| LTC1164CN Linear Technology  | по запросу | ||
| Корпус | N-24 |
| Код корпуса | N |
| Индекс корпуса | 05-08-1510 (N24) |
| Clock Tunable | да |
| Экспортный контроль | нет |
| Filter Order | 8 order |
| Filters Per Package | 4 |
| Fo Max | 20 kHz |
| Fo Min | 1 kHz |
| Fo/Fclk | 100, 50:1 |
| Isupply | 4 мА |
| Рабочий диапазон температур | от 0 до 70 °C |
| Preconfigured | Universal |
| Vs макс. | 16 В |
| Vs мин. | 4.75 В |
- Better than Bessel Linear Phase Filters For Data Communications &mdash AN56PDF, 311 Кб, Файл опубликован: 1 янв 1994
The pace of the world of digital communications is increasing at a tremendous rate. Each day the engineer is requested to compact more data in the same channel bandwidth with closer channel spacing. This application note discusses some of the requirements and techniques for using the new LTC1064/1164 and LTC1264-7 filters which were designed specifically for digital communications. The terms "channel bandwidth," "eye diagrams" and "linear phase" filtering are discussed without the need for the "engineering speak" which permeates many textbook explanations of the same subjects.Выписка из документа
Серия: LTC1164 (6)
- Signal Conditioning > Filters > Filter Building Blocks
LTC1164CNPBF, LTC1164CN PBF
