Линейка продуктов KEEN SIDE
Datasheet Linear Technology LT1009IZ#TRPBF — Даташит
СерияLT1009IZ
МодельLT1009IZ#TRPBF
Опорное напряжение 2,5 В
Datasheet LT1009
PDF, 120 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 8
2.5V Reference
12 предложений от 10 поставщиков
Опорный чип напряжения, V-Ref Precision 2.5V 3Pin TO-92 T/R
727GS
LT1009IZ#TRPBF
от 117 ₽
LT1009IZ#TRPBF
157 ₽
LT1009IZ#TRPBF
от 242 ₽
LT1009IZ#TRPBF
КорпусTO-92
Код корпусаZ
Индекс корпуса05-08-1410
Design ToolsLTspice Model
Экспортный контрольнет
Initial Accuracy0.2 %
Min Vin/Vout DifferentialShunt В
Диапазон выходных токовShunt
Quiescent or Min Shunt Current400 мкА
Ref Vout2.5 В
Series/ShuntShunt
Temp Co35 ppm/В°C
LT1009 Series LT1009CMS8 LT1009CZ LT1009IS8 LT1009S8
  • Designing Linear Circuits for 5V Single Supply Operation &mdash AN11
    PDF, 230 Кб, Файл опубликован: 1 сен 1985
    This note covers the considerations for designing precision linear circuits which must operate from a single 5V supply. Applications include various transducer signal conditioners, instrumentation amplifiers, controllers and isolated data converters.
  • High Speed Comparator Techniques &mdash AN13
    PDF, 1.1 Мб, Файл опубликован: 1 апр 1985
    The AN13 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section presents circuits, including a 0.025% accurate 1Hz to 30MHz V/F converter, a 200ns 0.01% sample-hold and a 10MHz fiber-optic receiver. Five appendices covering related topics complete this note.
  • Designs for High Performance Voltage-to-Frequency Converters &mdash AN14
    PDF, 387 Кб, Файл опубликован: 1 мар 1986
    A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.
  • Thermocouple Measurement &mdash AN28
    PDF, 988 Кб, Файл опубликован: 1 фев 1988
    Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.
  • Some Thoughts on DC-DC Converters &mdash AN29
    PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
    This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.
  • Applications for a Switched-Capacitor Instrumentation Building Block &mdash AN3
    PDF, 1.5 Мб, Файл опубликован: 1 июл 1985
    This application note describes a wide range of useful applications for the LTC1043 dual precision instrumentation switched capacitor building block. Some of the applications described are ultra high performance instrumentation amplifier, lock-in amplifier, wide range digitally controlled variable gain amplifier, relative humidity sensor signal conditioner, LVDT signal conditioner, charge pump F/V and V/F converters, 12-bit A/D converter and more.
  • Voltage Reference Circuit Collection &mdash AN42
    PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
    A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Applications of New Precision Op Amps &mdash AN6
    PDF, 784 Кб, Файл опубликован: 1 янв 1985
    Application considerations and circuits for the LT1001 and LT1002 single and dual precision amplifiers are illustrated in a number of circuits, including strain gauge signal conditioners, linearized platinum RTD circuits, an ultra precision dead zone circuit for motor servos and other examples.
  • Some Techniques for Direct Digitization of Transducer Outputs &mdash AN7
    PDF, 297 Кб, Файл опубликован: 1 фев 1985
    Analog-to-digital conversion circuits which directly digitize low level transducer outputs, without DC preamplification, are presented. Covered are circuits which operate with thermocouples, strain gauges, humidity sensors, level transducers and other sensors.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
Design Notes
  • Data Acquisition Systems Communicate with Microprocessors Over 4 Wires &mdash DN1
    PDF, 75 Кб, Файл опубликован: 1 авг 1987
  • Designing with a New Family of Instrumentation Amplifiers &mdash DN40
    PDF, 554 Кб, Файл опубликован: 1 окт 1990
  • Signal Conditioning for Platinum Temperature Transducers &mdash DN45
    PDF, 69 Кб, Файл опубликован: 1 мар 1991
Статьи
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
Серия: LT1009IZ (2)
  • Signal Conditioning > Voltage References > Shunt Voltage References
  • Space & Harsh Environment > Space Qualified Products > Space Qualified Voltage References
  • Space & Harsh Environment > Military Hermetic (M)
LT1009IZTRPBF, LT1009IZ TRPBF
На английском языке: Datasheet Linear Technology LT1009IZ#TRPBF
