Оптопары и оптореле Megawin
Datasheet Linear Technology LT1019AIS8-5#PBF — Даташит
СерияLT1019IS8-5
МодельLT1019AIS8-5#PBF
Справочник по точности
Datasheet LT1019
PDF, 164 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Precision Reference
30 предложений от 20 поставщиков
LT1019AIS8-5#PBF
от 1 765 ₽
Hi-Tech Circuit Group
LT1019AIS8-5#TRPBF
LT1019AIS8-5#TRPBF
LT1019AIS85
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Экспортный контрольнет
Initial Accuracy0.2 %
Line Reg.5 ppm/V
Load Reg.02 ppm/mA
Low Freq Noise12 µVPP
Min Vin/Vout Differential1.1 В
Диапазон выходных токовВ±10mA
Quiescent or Min Shunt Current650 мкА
Ref Vout5 В
Series/ShuntSeries
Temp Co5 ppm/В°C
Vin Max40 В
Vin Min5.9 В
LT1019 LT1019ACN8-10 LT1019ACN8-2.5 LT1019ACN8-4.5 LT1019ACN8-5 LT1019ACS8-2.5 LT1019ACS8-5 LT1019AIS8-2.5 LT1019AIS8-5 LT1019CN8-10 LT1019CN8-2.5 LT1019CN8-4.5 LT1019CN8-5 LT1019CS8-10 LT1019CS8-2.5 LT1019CS8-4.5 LT1019CS8-5 LT1019IN8-10 LT1019IN8-2.5 LT1019IN8-4.5 LT1019IN8-5 LT1019IS8-2.5
  • High Voltage, Low Noise, DC/DC Converters &mdash AN118
    PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
    Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator configurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output filtering methods that are usually impractical.
  • Thermocouple Measurement &mdash AN28
    PDF, 988 Кб, Файл опубликован: 1 фев 1988
    Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.
  • Converting Light to Digits: LTC1099 Half Flash 8-Bit A/D Converter Digitizes Photodiode Array &mdash AN33
    PDF, 703 Кб, Файл опубликован: 2 мар 1989
    This application note describes a Linear Technology "Half-Flash" A/D converter, the LTC1099, being connected to a 256 element line scan photodiode array. This technology adapts itself to handheld (i.e., low power) bar code readers, as well as high resolution automated machine inspection applications.
  • Voltage Reference Circuit Collection &mdash AN42
    PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
    A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
  • Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52
    PDF, 190 Кб, Файл опубликован: 1 янв 1993
    This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
Design Notes
  • Temperature Measurement Using Data Acquisition Systems &mdash DN5
    PDF, 77 Кб, Файл опубликован: 1 мар 1989
Статьи
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
  • Signal Conditioning > Voltage References > Series Voltage References
LT1019AIS8-5PBF, LT1019AIS8-5 PBF, LT1019AIS85#PBF, LT1019AIS8 5#PBF
На английском языке: Datasheet Linear Technology LT1019AIS8-5#PBF
