Datasheet Linear Technology LT1021CIN8-10#PBF — Даташит
Серия | LT1021CIN8-10 |
Модель | LT1021CIN8-10#PBF |
Справочник по точности
Datasheet LT1021
PDF, 239 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 16
Precision Reference
Precision Reference
![]() 25 предложений от 12 поставщиков Опорный чип напряжения, V-Ref Precision 10V 10mA 8Pin PDIP N | |||
LT1021CIN8-10 Linear Technology | 391 ₽ | ||
LT1021CIN8-10#PBF Analog Devices | 1 059 ₽ | ||
LT1021CIN8-10#PBF Analog Devices | от 1 401 ₽ | ||
LT1021CIN8-10 Linear Technology | по запросу |
Корпус | N-8 |
Код корпуса | N |
Индекс корпуса | 05-08-1510 (N8) |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Initial Accuracy | 0.05 % |
Line Reg | 1 ppm/V |
Load Reg | 12 ppm/mA |
Low Freq Noise | 6 µVPP |
Min Vin/Vout Differential | 2.2 В |
Диапазон выходных токов | В±10mA |
Quiescent or Min Shunt Current | 800 мкА |
Ref Vout | 10 В |
Series/Shunt | Series |
Temp Co | 5 ppm/В°C |
Vin Max | 40 В |
Vin Min | 11 В |
LT1021 LT1021BCH-5 LT1021BCN8-10 LT1021BCN8-5 LT1021BCN8-7 LT1021CCN8-10 LT1021CCN8-5 LT1021CIN8-5 LT1021DCN8-10 LT1021DCN8-5 LT1021DCN8-7 LT1021DCS8-10 LT1021DCS8-5 LT1021DCS8-7 LT1021DIN8-10 LT1021DIN8-5
- High Speed Comparator Techniques &mdash AN13PDF, 1.1 Мб, Файл опубликован: 1 апр 1985
The AN13 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section presents circuits, including a 0.025% accurate 1Hz to 30MHz V/F converter, a 200ns 0.01% sample-hold and a 10MHz fiber-optic receiver. Five appendices covering related topics complete this note.Выписка из документа - Designs for High Performance Voltage-to-Frequency Converters &mdash AN14PDF, 387 Кб, Файл опубликован: 1 мар 1986
A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.Выписка из документа - Considerations for Successive Approximation A ->D Converters &mdash AN17PDF, 641 Кб, Файл опубликован: 1 дек 1985
A tutorial on SAR type A/D converters, this note contains detailed information on several 12-bit circuits. Comparator, clocking, and preamplifier designs are discussed. A final circuit gives a 12-bit conversion in 1.8µs. Appended sections explain the basic SAR technique and explore D/A considerations.Выписка из документа - Micropower Circuits for Signal Conditioning &mdash AN23PDF, 2.2 Мб, Файл опубликован: 1 апр 1987
Low power operation of electronic apparatus has become increasingly desirable. AN23 describes a variety of low power circuits for transducer signal conditioning. Also included are designs for data converters and switching regulators. Three appended sections discuss guidelines for micropower design, strobed power operation and effects of test equipment on micropower circuits.Выписка из документа - Some Thoughts on DC-DC Converters &mdash AN29PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.Выписка из документа - Voltage Reference Circuit Collection &mdash AN42PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques. - Bridge Circuits &mdash AN43PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.Выписка из документа - Data Acquisition Circuit Collection &mdash AN62PDF, 349 Кб, Файл опубликован: 1 окт 1994
This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.Выписка из документа - Some Techniques for Direct Digitization of Transducer Outputs &mdash AN7PDF, 297 Кб, Файл опубликован: 1 фев 1985
Analog-to-digital conversion circuits which directly digitize low level transducer outputs, without DC preamplification, are presented. Covered are circuits which operate with thermocouples, strain gauges, humidity sensors, level transducers and other sensors.Выписка из документа - Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74PDF, 980 Кб, Файл опубликован: 1 июл 1998
DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.Выписка из документа - Understanding and Applying Voltage References &mdash AN82PDF, 172 Кб, Файл опубликован: 1 ноя 1999
Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.Выписка из документа - A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86PDF, 540 Кб, Файл опубликован: 1 янв 2001
This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.Выписка из документа
Design Notes
- Electrically Isolating Data Acquisition Systems &mdash DN10PDF, 73 Кб, Файл опубликован: 1 май 1988Выписка из документа
- Micropower ADC and DAC in SO-8 Give PCs a 12-Bit Analog Interface &mdash DN138PDF, 78 Кб, Файл опубликован: 3 сен 1996Выписка из документа
- A Two Wire Isolated and Powered 10-Bit Data Acquisition System &mdash DN19PDF, 81 Кб, Файл опубликован: 1 янв 1989Выписка из документа
- A Single Supply RS232 Interface for Bipolar A to D Converters &mdash DN29PDF, 455 Кб, Файл опубликован: 1 дек 1989Выписка из документа
- 250ksps, 16-Bit Micropower ADC Offers an Excellent Combination of SIze, Power and Speed &mdash DN294PDF, 54 Кб, Файл опубликован: 2 сен 2002Выписка из документа
- 12-Bit 8-Channel Data Acquisition System Interfaces to IBM PC Serial Port &mdash DN35PDF, 101 Кб, Файл опубликован: 1 июн 1990Выписка из документа
Статьи
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT JournalPDF, 262 Кб, Файл опубликован: 1 авг 1998Выписка из документа
- How to Choose a Voltage Reference &mdash LT JournalPDF, 282 Кб, Файл опубликован: 1 мар 2009Выписка из документа
- Dual Operational Amplifier Combines 16-Bit Precision with High Speed &mdash LT JournalPDF, 230 Кб, Файл опубликован: 1 май 2000Выписка из документа
Серия: LT1021CIN8-10 (1)
- LT1021CIN8-10#PBF
- Space & Harsh Environment > Military Hermetic (M)
- Signal Conditioning > Voltage References > Series Voltage References
- Space & Harsh Environment > Space Qualified Products > Space Qualified Voltage References
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Voltage References
LT1021CIN8-10PBF, LT1021CIN8-10 PBF, LT1021CIN810#PBF, LT1021CIN8 10#PBF
