Datasheet Linear Technology LT1021CIN8-5#PBF — Даташит
СерияLT1021CIN8-5
МодельLT1021CIN8-5#PBF
Справочник по точности
Datasheet LT1021
PDF, 239 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 16
Precision Reference
30 предложений от 16 поставщиков
Опорный чип напряжения, V-Ref Precision 5V 10mA 8Pin PDIP N
LT1021CIN8-5
388 ₽
LT1021CIN8-5
390 ₽
Эиком
LT1021CIN8-5#PBF
от 1 526 ₽
ЗУМ-СМД
LT1021CIN8-5
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Design ToolsLTspice Model
Экспортный контрольнет
Initial Accuracy0.05 %
Line Reg1 ppm/V
Load Reg10 ppm/mA
Low Freq Noise3 µVPP
Min Vin/Vout Differential2.2 В
Диапазон выходных токовВ±10mA
Quiescent or Min Shunt Current800 мкА
Ref Vout5 В
Series/ShuntSeries
Temp Co3 ppm/В°C
Vin Max40 В
Vin Min6 В
LT1021 LT1021BCH-5 LT1021BCN8-10 LT1021BCN8-5 LT1021BCN8-7 LT1021CCN8-10 LT1021CCN8-5 LT1021CIN8-10 LT1021DCN8-10 LT1021DCN8-5 LT1021DCN8-7 LT1021DCS8-10 LT1021DCS8-5 LT1021DCS8-7 LT1021DIN8-10 LT1021DIN8-5
  • High Speed Comparator Techniques &mdash AN13
    PDF, 1.1 Мб, Файл опубликован: 1 апр 1985
    The AN13 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section presents circuits, including a 0.025% accurate 1Hz to 30MHz V/F converter, a 200ns 0.01% sample-hold and a 10MHz fiber-optic receiver. Five appendices covering related topics complete this note.
  • Designs for High Performance Voltage-to-Frequency Converters &mdash AN14
    PDF, 387 Кб, Файл опубликован: 1 мар 1986
    A variety of high performance V/F circuits is presented. Included are a 1Hz to 100MHz design, a quartz-stabilized type and a 0.0007% linear unit. Other circuits feature 1.5V operation, sine wave output an nonlinear transfer functions. A separate section examines the trade-offs and advantages of various approaches to V/F conversion.
  • Considerations for Successive Approximation A ->D Converters &mdash AN17
    PDF, 641 Кб, Файл опубликован: 1 дек 1985
    A tutorial on SAR type A/D converters, this note contains detailed information on several 12-bit circuits. Comparator, clocking, and preamplifier designs are discussed. A final circuit gives a 12-bit conversion in 1.8µs. Appended sections explain the basic SAR technique and explore D/A considerations.
  • Micropower Circuits for Signal Conditioning &mdash AN23
    PDF, 2.2 Мб, Файл опубликован: 1 апр 1987
    Low power operation of electronic apparatus has become increasingly desirable. AN23 describes a variety of low power circuits for transducer signal conditioning. Also included are designs for data converters and switching regulators. Three appended sections discuss guidelines for micropower design, strobed power operation and effects of test equipment on micropower circuits.
  • Some Thoughts on DC-DC Converters &mdash AN29
    PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
    This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.
  • Voltage Reference Circuit Collection &mdash AN42
    PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
    A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
  • Bridge Circuits &mdash AN43
    PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
    Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.
  • Data Acquisition Circuit Collection &mdash AN62
    PDF, 349 Кб, Файл опубликован: 1 окт 1994
    This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.
  • Some Techniques for Direct Digitization of Transducer Outputs &mdash AN7
    PDF, 297 Кб, Файл опубликован: 1 фев 1985
    Analog-to-digital conversion circuits which directly digitize low level transducer outputs, without DC preamplification, are presented. Covered are circuits which operate with thermocouples, strain gauges, humidity sensors, level transducers and other sensors.
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
Design Notes
  • Electrically Isolating Data Acquisition Systems &mdash DN10
    PDF, 73 Кб, Файл опубликован: 1 май 1988
  • Micropower ADC and DAC in SO-8 Give PCs a 12-Bit Analog Interface &mdash DN138
    PDF, 78 Кб, Файл опубликован: 3 сен 1996
  • A Two Wire Isolated and Powered 10-Bit Data Acquisition System &mdash DN19
    PDF, 81 Кб, Файл опубликован: 1 янв 1989
  • A Single Supply RS232 Interface for Bipolar A to D Converters &mdash DN29
    PDF, 455 Кб, Файл опубликован: 1 дек 1989
  • 250ksps, 16-Bit Micropower ADC Offers an Excellent Combination of SIze, Power and Speed &mdash DN294
    PDF, 54 Кб, Файл опубликован: 2 сен 2002
  • 12-Bit 8-Channel Data Acquisition System Interfaces to IBM PC Serial Port &mdash DN35
    PDF, 101 Кб, Файл опубликован: 1 июн 1990
Статьи
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT Journal
    PDF, 262 Кб, Файл опубликован: 1 авг 1998
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
  • Dual Operational Amplifier Combines 16-Bit Precision with High Speed &mdash LT Journal
    PDF, 230 Кб, Файл опубликован: 1 май 2000
Серия: LT1021CIN8-5 (1)
  • LT1021CIN8-5#PBF
  • Space & Harsh Environment > Military Hermetic (M)
  • Signal Conditioning > Voltage References > Series Voltage References
  • Space & Harsh Environment > Space Qualified Products > Space Qualified Voltage References
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Voltage References
LT1021CIN8-5PBF, LT1021CIN8-5 PBF, LT1021CIN85#PBF, LT1021CIN8 5#PBF
На английском языке: Datasheet Linear Technology LT1021CIN8-5#PBF
