Datasheet Linear Technology LT1236BIN8-5#PBF — Даташит
| Серия | LT1236BIN8-5 |
| Модель | LT1236BIN8-5#PBF |
Справочник по точности
Datasheet LT1236
PDF, 230 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Precision Reference
Precision Reference
Купить LT1236BIN8-5#PBF на РадиоЛоцман.Цены — от 133 до 829 ₽13 предложений от 13 поставщиков IC VREF SERIES 0.1% 8DIP. Series, Buried Zener Voltage Reference IC ±0.1% 8-PDIP. PMIC - Voltage Reference | |||
| LT1236BIN8-5#PBF Analog Devices | 138 ₽ | ||
| LT1236BIN8-5 Analog Devices | 829 ₽ | ||
| LT1236BIN8-5 Linear Technology | по запросу | ||
| LT1236BIN8-5#PBF Linear Technology | по запросу | ||
| Корпус | N-8 |
| Код корпуса | N |
| Индекс корпуса | 05-08-1510 (N8) |
| Design Tools | LTspice Model |
| Экспортный контроль | нет |
| Initial Accuracy | 0.1 % |
| Line Reg | 4 ppm/V |
| Load Reg | 10 ppm/mA |
| Low Freq Noise | 3 µVPP |
| Min Vin/Vout Differential | 1 В |
| Диапазон выходных токов | В±10mA |
| Quiescent or Min Shunt Current | 800 мкА |
| Ref Vout | 5 В |
| Series/Shunt | Series |
| Temp Co | 5 ppm/В°C |
| Vin Max | 40 В |
LT1236 LT1236ACN8-10 LT1236ACN8-5 LT1236ACS8-10 LT1236ACS8-5 LT1236AIN8-10 LT1236AIS8-10 LT1236AIS8-5 LT1236BCN8-10 LT1236BCN8-5 LT1236BCS8-10 LT1236BCS8-5 LT1236BIN8-10 LT1236BIS8-10 LT1236BIS8-5 LT1236CCN8-10 LT1236CCN8-5 LT1236CCS8-10 LT1236CCS8-5 LT1236CIN8-10 LT1236CIN8-5 LT1236CIS8-10 LT1236CIS8-5
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74PDF, 980 Кб, Файл опубликован: 1 июл 1998
DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.Выписка из документа - Understanding and Applying Voltage References &mdash AN82PDF, 172 Кб, Файл опубликован: 1 ноя 1999
Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.Выписка из документа - A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86PDF, 540 Кб, Файл опубликован: 1 янв 2001
This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.Выписка из документа
Design Notes
- New Voltage References Are Smaller and More Precise &mdash DN145PDF, 84 Кб, Файл опубликован: 1 янв 1997Выписка из документа
- 24-Bit ADC Measures from DC to Daylight &mdash DN219PDF, 76 Кб, Файл опубликован: 1 дек 1999Выписка из документа
- Don't Be Fooled By Voltage Reference Long-Term Drift and Hysteresis &mdash DN229PDF, 98 Кб, Файл опубликован: 3 апр 2001Выписка из документа
- Dual 25ВµV Micropower Op Amp Fits in 3mm x 3mm Package &mdash DN331PDF, 82 Кб, Файл опубликован: 2 фев 2004Выписка из документа
Статьи
- Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT JournalPDF, 262 Кб, Файл опубликован: 1 авг 1998Выписка из документа
- LTC2400 Differential Bridge Digitizers &mdash LT JournalPDF, 120 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- How to Choose a Voltage Reference &mdash LT JournalPDF, 282 Кб, Файл опубликован: 1 мар 2009Выписка из документа
Серия: LT1236BIN8-5 (1)
- LT1236BIN8-5#PBF
- Signal Conditioning > Voltage References > Series Voltage References
LT1236BIN8-5PBF, LT1236BIN8-5 PBF, LT1236BIN85#PBF, LT1236BIN8 5#PBF
