Datasheet Linear Technology LT1236BIS8-5#PBF — Даташит
СерияLT1236BIS8-5
МодельLT1236BIS8-5#PBF
Справочник по точности
Datasheet LT1236
PDF, 230 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Precision Reference
42 предложений от 23 поставщиков
LT1236BIS8-5
127 ₽
Зенер
Россия и страны ТС
LT1236BIS8-5#TRPBF
от 320 ₽
LT1236BIS85#TR
TradeElectronics
LT1236BIS8-5
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Design ToolsLTspice Model
Экспортный контрольнет
Initial Accuracy0.1 %
Line Reg4 ppm/V
Load Reg10 ppm/mA
Low Freq Noise3 µVPP
Min Vin/Vout Differential1 В
Диапазон выходных токовВ±10mA
Quiescent or Min Shunt Current800 мкА
Ref Vout5 В
Series/ShuntSeries
Temp Co5 ppm/В°C
Vin Max40 В
LT1236 LT1236ACN8-10 LT1236ACN8-5 LT1236ACS8-10 LT1236ACS8-5 LT1236AIN8-10 LT1236AIS8-10 LT1236AIS8-5 LT1236BCN8-10 LT1236BCN8-5 LT1236BCS8-10 LT1236BCS8-5 LT1236BIN8-10 LT1236BIN8-5 LT1236BIS8-10 LT1236CCN8-10 LT1236CCN8-5 LT1236CCS8-10 LT1236CCS8-5 LT1236CIN8-10 LT1236CIN8-5 LT1236CIS8-10 LT1236CIS8-5
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
Design Notes
  • New Voltage References Are Smaller and More Precise &mdash DN145
    PDF, 84 Кб, Файл опубликован: 1 янв 1997
  • 24-Bit ADC Measures from DC to Daylight &mdash DN219
    PDF, 76 Кб, Файл опубликован: 1 дек 1999
  • Don't Be Fooled By Voltage Reference Long-Term Drift and Hysteresis &mdash DN229
    PDF, 98 Кб, Файл опубликован: 3 апр 2001
  • Dual 25ВµV Micropower Op Amp Fits in 3mm x 3mm Package &mdash DN331
    PDF, 82 Кб, Файл опубликован: 2 фев 2004
Статьи
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT Journal
    PDF, 262 Кб, Файл опубликован: 1 авг 1998
  • LTC2400 Differential Bridge Digitizers &mdash LT Journal
    PDF, 120 Кб, Файл опубликован: 1 июн 1999
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
Серия: LT1236BIS8-5 (2)
  • Signal Conditioning > Voltage References > Series Voltage References
LT1236BIS8-5PBF, LT1236BIS8-5 PBF, LT1236BIS85#PBF, LT1236BIS8 5#PBF
На английском языке: Datasheet Linear Technology LT1236BIS8-5#PBF
