Datasheet Linear Technology LT1389BCS8-5#PBF — Даташит
СерияLT1389
МодельLT1389BCS8-5#PBF
Прецизионный шунтирующий опорный источник напряжения Nanopower
Datasheet LT1389
PDF, 219 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 12
Nanopower Precision Shunt Voltage Reference
41 предложений от 21 поставщиков
LT1389BCS8-5#PBF
от 145 ₽
TradeElectronics
LT1389BCS85
Hi-Tech Circuit Group
LT1389BCS8-5#TRPBF
МосЧип
LT1389BCS8-5
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Design ToolsLTspice Model
Экспортный контрольнет
Initial Accuracy0.075 %
Low Freq Noise100 µVPP
Min Vin/Vout DifferentialShunt В
Диапазон выходных токовShunt
Quiescent or Min Shunt Current0.6 мкА
Ref Vout5 В
Series/ShuntShunt
Temp Co12 ppm/В°C
LTC6655
  • Circuitry for Signal Conditioning and Power Conversion &mdash AN75
    PDF, 508 Кб, Файл опубликован: 1 мар 1999
    This publication includes designs for data converters and signal conditioners, transducer circuits, crystal oscillators and power converters. Wideband and micropower circuitry receive special attention. Tutorials on micropower design techniques and parasitic effects of test equipment are included.
  • Instrumentation Applications for a Monolithic Oscillator: A Clock for All Reasons &mdash AN93
    PDF, 1.1 Мб, Файл опубликован: 1 фев 2003
    Instrumentation applications for a monolithic programmable oscillator are presented in this publication. Circuits include platinum and thermistor based thermometers, an isolated thermometer and three relative humidity signal conditioners. Bipolar and FET input chopper stabilized amplifiers with noise below 45nV (0.1Hz to 10Hz) are detailed. Two clock tunable sine wave generators with settable amplitude appear, as well as a tunable notch filter, an interval generator and an A to D converter. The oscillator's performance is contrasted against other approaches and its interval operation discussed.
Design Notes
  • UL Isolated Self-Powered Sensing &mdash DN204
    PDF, 80 Кб, Файл опубликован: 3 апр 1999
Статьи
  • Avoid Debugging Cycles in Power Management for FPGA, GPU and ASIC Systems &mdash LT Journal
    PDF, 3.2 Мб, Файл опубликован: 25 авг 2016
  • 4.5µA Li-Ion Battery Protection Circuit &mdash LT Journal
    PDF, 114 Кб, Файл опубликован: 1 июн 1999
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
  • Signal Conditioning > Voltage References > Shunt Voltage References | Micropower Voltage References
LT1389BCS8-5PBF, LT1389BCS8-5 PBF, LT1389BCS85#PBF, LT1389BCS8 5#PBF
На английском языке: Datasheet Linear Technology LT1389BCS8-5#PBF
