Datasheet Linear Technology LT1431CZ#TRPBF — Даташит
| Серия | LT1431CZ |
| Модель | LT1431CZ#TRPBF |
Программируемый эталон
Datasheet LT1431
PDF, 233 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 14
Programmable Reference
|  Купить LT1431CZ#TRPBF на РадиоЛоцман.Цены — от 43 до 119 ₽ 14 предложений от 14 поставщиков IC VREF SHUNT 36V 0.4% TO92-3. Shunt Voltage Reference IC 36V ±0.4% TO-92-3. PMIC - Voltage Reference | |||
| LT1431CZ#TRPBF Linear Technology | 108 ₽ | ||
| LT1431CZ#TRPBF Linear Technology | по запросу | ||
| LT1431CZ#TRPBF Analog Devices | по запросу | ||
| Корпус | TO-92 |
| Код корпуса | Z |
| Индекс корпуса | 05-08-1410 |
| Demo Boards | DC259A |
| Design Tools | LTspice File |
| Экспортный контроль | нет |
| Initial Accuracy | 0.4 % |
| Min Vin/Vout Differential | Shunt В |
| Рабочий диапазон температур | от 0 до 70 °C |
| Диапазон выходных токов | Shunt |
| Quiescent or Min Shunt Current | 600 мкА |
| Ref Vout | 5 В |
| Series/Shunt | Shunt |
| Temp Co | 30 ppm/В°C |
LT1431 LT1431CN8 LT1431CS8 LT1431IN8 LT1431IS8 LT1431IZ LT1431MPS8
- Voltage Reference Circuit Collection &mdash AN42PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
 A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
- Efficiency and Power Characteristics of Switching Regulator Circuits &mdash AN46PDF, 2.6 Мб, Файл опубликован: 1 ноя 1991
 Efficiency varies for different DC/DC converters. This application note compares the efficiency characteristics of some of the more popular types. Step-up, step-down, flyback, negative-to-positive, and positive-to-negative are shown. Appended sections discuss how to select the proper aluminum electrolytic capacitor and explain power switch and output diode loss calculations.
- Data Acquisition Circuit Collection &mdash AN62PDF, 349 Кб, Файл опубликован: 1 окт 1994
 This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.Выписка из документа
- A Monolithic Switching Regulator with 100ВµV Output Noise &mdash AN70PDF, 1.7 Мб, Язык: анг., Файл опубликован: 1 окт 1997
 This publication details circuitry and applications considerations for the LT1533 low noise switching regulator. Eleven DC/DC converter circuits are presented, some offering <100µV output noise in a 100MHz bandwidth. Tutorial sections detail low noise DC/DC design, measurement, probing and layout techniques, and magnetics selection.Выписка из документа
- Circuitry for Signal Conditioning and Power Conversion &mdash AN75PDF, 508 Кб, Файл опубликован: 1 мар 1999
 This publication includes designs for data converters and signal conditioners, transducer circuits, crystal oscillators and power converters. Wideband and micropower circuitry receive special attention. Tutorials on micropower design techniques and parasitic effects of test equipment are included.Выписка из документа
- Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90PDF, 409 Кб, Файл опубликован: 1 апр 2002
 A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.Выписка из документа
Design Notes
- Single IC, Power Factor Corrected, Off-Line Supply &mdash DN143PDF, 140 Кб, Файл опубликован: 1 дек 1996Выписка из документа
- Off-Line Low Noise Power Supply Does Not Require Filtering to Meet FCC Emission Requirements &mdash DN175PDF, 113 Кб, Файл опубликован: 1 мар 1998Выписка из документа
- A Simple Ultra-Low Dropout Regulator &mdash DN32PDF, 95 Кб, Файл опубликован: 1 мар 1990Выписка из документа
- A 4-Cell Ni-Cad Regulator/Charger for Notebook Computers &mdash DN54PDF, 77 Кб, Файл опубликован: 1 ноя 1991Выписка из документа
Статьи
- Synchronous, Phase Modulated, Full Bridge Converter Targets Isolated High Power Applications &mdash LT JournalPDF, 313 Кб, Файл опубликован: 1 сен 2003Выписка из документа
Серия: LT1431CZ (2)
- LT1431CZ#PBF LT1431CZ#TRPBF
- Signal Conditioning > Voltage References > Shunt Voltage References
- Space & Harsh Environment > Military Hermetic (M)
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Voltage References
LT1431CZTRPBF, LT1431CZ TRPBF
