Datasheet Linear Technology LT1790ACS6-4.096#PBF — Даташит
СерияLT1790ACS6-4.096
МодельLT1790ACS6-4.096#PBF
Эталонное семейство Micropower SOT-23 с низким падением напряжения
Datasheet LT1790
PDF, 596 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 26
Micropower SOT-23 Low Dropout Reference Family
30 предложений от 18 поставщиков
Опорный чип напряжения, Series Voltage Reference IC ±0.05% 5mA SOT-23-6 Thin, TSOT-23-6
LT1790ACS6-4.096#TRM
234 ₽
727GS
LT1790ACS6-4.096#TRMPBF
от 362 ₽
от 849 ₽
LT1790ACS6-4.096#TR
КорпусSOT-23
Код корпусаS6
Индекс корпуса05-08-1636
Design ToolsLTspice File
Экспортный контрольнет
Initial Accuracy0.05 %
Line Reg50 ppm/V
Load Reg100 ppm/mA
Low Freq Noise60 µVPP
Min Vin/Vout Differential0.1 В
Диапазон выходных токов-1mA to 5mA
Quiescent or Min Shunt Current35 мкА
Ref Vout4.096 В
Series/ShuntSeries
Temp Co5 ppm/В°C
Vin Max18 В
Vin Min4.146 В
LT1790 LT1790ACS6-1.25 LT1790ACS6-2.048 LT1790ACS6-2.5 LT1790ACS6-3 LT1790ACS6-3.3 LT1790ACS6-5 LT1790AIS6-1.25 LT1790AIS6-2.048 LT1790AIS6-2.5 LT1790AIS6-3 LT1790AIS6-3.3 LT1790AIS6-4.096 LT1790AIS6-5 LT1790BCS6-1.25 LT1790BCS6-2.048 LT1790BCS6-2.5 LT1790BCS6-3 LT1790BCS6-3.3 LT1790BCS6-4.096 LT1790BCS6-5 LT1790BIS6-1.25 LT1790BIS6-2.048 LT1790BIS6-2.5 LT1790BIS6-3 LT1790BIS6-3.3 LT1790BIS6-4.096 LT1790BIS6-5
  • Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90
    PDF, 409 Кб, Файл опубликован: 1 апр 2002
    A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.
Design Notes
  • Don't Be Fooled By Voltage Reference Long-Term Drift and Hysteresis &mdash DN229
    PDF, 98 Кб, Файл опубликован: 3 апр 2001
  • Dual 25ВµV Micropower Op Amp Fits in 3mm x 3mm Package &mdash DN331
    PDF, 82 Кб, Файл опубликован: 2 фев 2004
  • 16-Bit ADC Simplifies Current Measurements &mdash DN341
    PDF, 78 Кб, Файл опубликован: 1 июл 2004
  • 6-Channel SAR ADCs for Industrial Monitoring and Portable &mdash DN426
    PDF, 112 Кб, Файл опубликован: 14 сен 2007
  • 12-bit DAC in TSOT-23 Includes Bidirectional REF Pin for Connection to Op Amp or External High Precision Reference &mdash DN448
    PDF, 87 Кб, Файл опубликован: 25 авг 2008
Статьи
  • SOT-23 Voltage Reference Has 0.05% Initial Accuracy, 10ppm/°C Tempco, Operates on 35µA &mdash LT Journal
    PDF, 207 Кб, Файл опубликован: 1 сен 2000
  • Signal Conditioning > Voltage References > Series Voltage References | Micropower Voltage References
LT1790ACS6-4.096PBF, LT1790ACS6-4.096 PBF, LT1790ACS64.096#PBF, LT1790ACS6 4.096#PBF
На английском языке: Datasheet Linear Technology LT1790ACS6-4.096#PBF
