Datasheet Linear Technology LT1790AIS6-5#TRMPBF — Даташит
СерияLT1790AIS6-5
МодельLT1790AIS6-5#TRMPBF
Эталонное семейство Micropower SOT-23 с низким падением напряжения
Datasheet LT1790
PDF, 596 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 26
Micropower SOT-23 Low Dropout Reference Family
28 предложений от 12 поставщиков
IC VREF SERIES 5V SOT23-6 / V-Ref Precision 5V 5mA Automotive 6-Pin TSOT-23 T/R
727GS
LT1790AIS6-5#TRMPBF
от 240 ₽
LT1790AIS6-5#TRMPBF
1 433 ₽
LT1790AIS6-5#TRMPBF
LT1790AIS6-5#TRMPBF
КорпусSOT-23
Код корпусаS6
Индекс корпуса05-08-1636
Design ToolsLTspice File
Экспортный контрольнет
Initial Accuracy0.05 %
Line Reg50 ppm/V
Load Reg100 ppm/mA
Low Freq Noise80 µVPP
Min Vin/Vout Differential0.1 В
Диапазон выходных токов-1mA to 5mA
Quiescent or Min Shunt Current35 мкА
Ref Vout5 В
Series/ShuntSeries
Temp Co5 ppm/В°C
Vin Max18 В
Vin Min5.05 В
LT1790 LT1790ACS6-1.25 LT1790ACS6-2.048 LT1790ACS6-2.5 LT1790ACS6-3 LT1790ACS6-3.3 LT1790ACS6-4.096 LT1790ACS6-5 LT1790AIS6-1.25 LT1790AIS6-2.048 LT1790AIS6-2.5 LT1790AIS6-3 LT1790AIS6-3.3 LT1790AIS6-4.096 LT1790BCS6-1.25 LT1790BCS6-2.048 LT1790BCS6-2.5 LT1790BCS6-3 LT1790BCS6-3.3 LT1790BCS6-4.096 LT1790BCS6-5 LT1790BIS6-1.25 LT1790BIS6-2.048 LT1790BIS6-2.5 LT1790BIS6-3 LT1790BIS6-3.3 LT1790BIS6-4.096 LT1790BIS6-5
  • Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90
    PDF, 409 Кб, Файл опубликован: 1 апр 2002
    A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.
Design Notes
  • Don't Be Fooled By Voltage Reference Long-Term Drift and Hysteresis &mdash DN229
    PDF, 98 Кб, Файл опубликован: 3 апр 2001
  • Dual 25ВµV Micropower Op Amp Fits in 3mm x 3mm Package &mdash DN331
    PDF, 82 Кб, Файл опубликован: 2 фев 2004
  • 16-Bit ADC Simplifies Current Measurements &mdash DN341
    PDF, 78 Кб, Файл опубликован: 1 июл 2004
  • 6-Channel SAR ADCs for Industrial Monitoring and Portable &mdash DN426
    PDF, 112 Кб, Файл опубликован: 14 сен 2007
  • 12-bit DAC in TSOT-23 Includes Bidirectional REF Pin for Connection to Op Amp or External High Precision Reference &mdash DN448
    PDF, 87 Кб, Файл опубликован: 25 авг 2008
Статьи
  • SOT-23 Voltage Reference Has 0.05% Initial Accuracy, 10ppm/°C Tempco, Operates on 35µA &mdash LT Journal
    PDF, 207 Кб, Файл опубликован: 1 сен 2000
Серия: LT1790AIS6-5 (3)
  • Signal Conditioning > Voltage References > Series Voltage References | Micropower Voltage References
LT1790AIS6-5TRMPBF, LT1790AIS6-5 TRMPBF, LT1790AIS65#TRMPBF, LT1790AIS6 5#TRMPBF
На английском языке: Datasheet Linear Technology LT1790AIS6-5#TRMPBF
