Datasheet Linear Technology LT1790BIS6-4.096#TRPBF — Даташит
Серия | LT1790BIS6-4.096 |
Модель | LT1790BIS6-4.096#TRPBF |
Эталонное семейство Micropower SOT-23 с низким падением напряжения
Datasheet LT1790
PDF, 596 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 26
Micropower SOT-23 Low Dropout Reference Family
![]() 15 предложений от 11 поставщиков IC VREF SERIES 4.096V SOT23-6 / V-Ref Precision 4.096V 5mA Automotive 6-Pin TSOT-23 T/R | |||
LT1790BIS6-4.096#TRPBF Analog Devices | 67 ₽ | ||
LT1790BIS6-4.096#TRPBF Linear Technology | по запросу | ||
LT1790BIS6-4.096#TRPBF Analog Devices | по запросу | ||
LT1790BIS6-4.096 TRPBF Linear Technology | по запросу |
Корпус | SOT-23 |
Код корпуса | S6 |
Индекс корпуса | 05-08-1636 |
Design Tools | LTspice File |
Экспортный контроль | нет |
Initial Accuracy | 0.1 % |
Line Reg | 50 ppm/V |
Load Reg | 100 ppm/mA |
Low Freq Noise | 60 µVPP |
Min Vin/Vout Differential | 0.1 В |
Диапазон выходных токов | -1mA to 5mA |
Quiescent or Min Shunt Current | 35 мкА |
Ref Vout | 4.096 В |
Series/Shunt | Series |
Temp Co | 12 ppm/В°C |
Vin Max | 18 В |
Vin Min | 4.146 В |
LT1790 LT1790ACS6-1.25 LT1790ACS6-2.048 LT1790ACS6-2.5 LT1790ACS6-3 LT1790ACS6-3.3 LT1790ACS6-4.096 LT1790ACS6-5 LT1790AIS6-1.25 LT1790AIS6-2.048 LT1790AIS6-2.5 LT1790AIS6-3 LT1790AIS6-3.3 LT1790AIS6-4.096 LT1790AIS6-5 LT1790BCS6-1.25 LT1790BCS6-2.048 LT1790BCS6-2.5 LT1790BCS6-3 LT1790BCS6-3.3 LT1790BCS6-4.096 LT1790BCS6-5 LT1790BIS6-1.25 LT1790BIS6-2.048 LT1790BIS6-2.5 LT1790BIS6-3 LT1790BIS6-3.3 LT1790BIS6-5
- Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90PDF, 409 Кб, Файл опубликован: 1 апр 2002
A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.Выписка из документа
Design Notes
- Don't Be Fooled By Voltage Reference Long-Term Drift and Hysteresis &mdash DN229PDF, 98 Кб, Файл опубликован: 3 апр 2001Выписка из документа
- Dual 25ВµV Micropower Op Amp Fits in 3mm x 3mm Package &mdash DN331PDF, 82 Кб, Файл опубликован: 2 фев 2004Выписка из документа
- 16-Bit ADC Simplifies Current Measurements &mdash DN341PDF, 78 Кб, Файл опубликован: 1 июл 2004Выписка из документа
- 6-Channel SAR ADCs for Industrial Monitoring and Portable &mdash DN426PDF, 112 Кб, Файл опубликован: 14 сен 2007Выписка из документа
- 12-bit DAC in TSOT-23 Includes Bidirectional REF Pin for Connection to Op Amp or External High Precision Reference &mdash DN448PDF, 87 Кб, Файл опубликован: 25 авг 2008Выписка из документа
Статьи
- SOT-23 Voltage Reference Has 0.05% Initial Accuracy, 10ppm/°C Tempco, Operates on 35µA &mdash LT JournalPDF, 207 Кб, Файл опубликован: 1 сен 2000Выписка из документа
Серия: LT1790BIS6-4.096 (3)
- LT1790BIS6-4.096#PBF LT1790BIS6-4.096#TRMPBF LT1790BIS6-4.096#TRPBF
- Signal Conditioning > Voltage References > Series Voltage References | Micropower Voltage References
LT1790BIS6-4.096TRPBF, LT1790BIS6-4.096 TRPBF, LT1790BIS64.096#TRPBF, LT1790BIS6 4.096#TRPBF
