Datasheet Linear Technology LTC1966CMS8#PBF — Даташит
| Серия | LTC1966 |
| Модель | LTC1966CMS8#PBF |
Precision Micropower О”ОЈ RMS-to-DC Converter
LTC1966 - Precision Micropower О”ОЈ RMS-to-DC Converter
PDF, 401 Кб, Версия: B, Файл закачен: 15 авг 2017
Купить LTC1966CMS8#PBF на РадиоЛоцман.Цены — от 129 до 3 175 ₽50 предложений от 27 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Преобразователи RMS в DC | |||
| LTC1966CMS8#TRPBF Analog Devices | 278 ₽ | ||
| LTC1966CMS8 Analog Devices | 894 ₽ | ||
| LTC1966CMS8 PBF Linear Technology | по запросу | ||
| LTC1966CMS8 Analog Devices | по запросу | ||
| Корпус | MS-8 |
| Код корпуса | MS8 |
| Индекс корпуса | 05-08-1660 |
| 1% Error Bandwidth | 6 kHz |
| 3dB Error Bandwidth | 800 kHz |
| Conversion Gain Error | 0.1 % |
| Demo Boards | DC427B-A |
| Design Tools | LTspice File |
| Экспортный контроль | нет |
| Isupply | 0.17 мА |
| Нелинейность | 0.02 % |
| Рабочий диапазон температур | от 0 до 70 °C |
| Vin Max | 1.05 В |
| Vs макс. | 12 В |
| Vs мин. | 2.7 В |
- Instrumentation Circuitry Using RMS-to-DC Converters &mdash AN106PDF, 354 Кб, Файл опубликован: 21 фев 2007
It is widely acknowledged that RMS measurement of waveforms furnishes the most accurate amplitude information. Rectify-andaverage schemes, usually calibrated to a sine wave, are only accurate for one waveshape. Departures from this waveshape result in pronounced errors. Although accurate, RMS conversion often entails limited bandwidth, restricted range, complexity and difп¬Ѓcult to characterize dynamic and static errors. The LTC1966/67/68 RMS converter family addresses these issues, making instrument grade applications practical. A variety of instrumentation oriented applications are presented. Included are basic circuits, a fully isolated AC line monitor, a distortionless AC line voltage regulator, wideband X1000 pre-ampliп¬Ѓers, a quartz crystal RMS current meter, a crystal stabilized AC voltage reference, an RMS amplitude leveled random noise generator and an RMS amplitude level controller. Appended sections cover RMS theory and converter operation, AC measurement and signal handling practice, test equipment recommendations, noise theory and noise diodes.Выписка из документа
Design Notes
- RMS-to-DC Conversion Just Got Easy &mdash DN288PDF, 82 Кб, Файл опубликован: 2 июн 2002Выписка из документа
- An Autoranging True RMS Converter &mdash DN339PDF, 77 Кб, Файл опубликован: 1 июн 2004Выписка из документа
Статьи
- Delta Sigma Breakthrough: LTC1966 True RMS-to-DC Converter Uses No Diodes, Heaters or Logarithms &mdash LT JournalPDF, 270 Кб, Файл опубликован: 1 мар 2002Выписка из документа
Серия: LTC1966 (8)
- Signal Conditioning > RMS-DC Conversion
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) System Monitor
LTC1966CMS8PBF, LTC1966CMS8 PBF
