Оптопары и оптореле Megawin
Datasheet Linear Technology LTC1966HMS8#TRPBF — Даташит
СерияLTC1966
МодельLTC1966HMS8#TRPBF
Precision Micropower О”ОЈ RMS-to-DC Converter
LTC1966 - Precision Micropower О”ОЈ RMS-to-DC Converter
PDF, 401 Кб, Версия: B, Файл закачен: 15 авг 2017
19 предложений от 12 поставщиков
Преобразователи RMS-DC 155мкА 2,7-5,5 В MSOP-8 Преобразователи среднеквадратического значения в постоянный ток
LTC1966HMS8#TRPBF
598 ₽
LTC1966HMS8#TRPBF
702 ₽
DIP8.RU
Россия и страны ТС
LTC1966HMS8#TRPBF
от 951 ₽
LTC1966HMS8#TRPBF
КорпусMS-8
Код корпусаMS8
Индекс корпуса05-08-1660
1% Error Bandwidth6 kHz
3dB Error Bandwidth800 kHz
Conversion Gain Error0.1 %
Demo BoardsDC427B-A
Design ToolsLTspice File
Экспортный контрольнет
Isupply0.17 мА
Нелинейность0.02 %
Рабочий диапазон температурот -40 до 125 °C
Vin Max1.05 В
Vs макс.12 В
Vs мин.2.7 В
  • Instrumentation Circuitry Using RMS-to-DC Converters &mdash AN106
    PDF, 354 Кб, Файл опубликован: 21 фев 2007
    It is widely acknowledged that RMS measurement of waveforms furnishes the most accurate amplitude information. Rectify-andaverage schemes, usually calibrated to a sine wave, are only accurate for one waveshape. Departures from this waveshape result in pronounced errors. Although accurate, RMS conversion often entails limited bandwidth, restricted range, complexity and difficult to characterize dynamic and static errors. The LTC1966/67/68 RMS converter family addresses these issues, making instrument grade applications practical. A variety of instrumentation oriented applications are presented. Included are basic circuits, a fully isolated AC line monitor, a distortionless AC line voltage regulator, wideband X1000 pre-amplifiers, a quartz crystal RMS current meter, a crystal stabilized AC voltage reference, an RMS amplitude leveled random noise generator and an RMS amplitude level controller. Appended sections cover RMS theory and converter operation, AC measurement and signal handling practice, test equipment recommendations, noise theory and noise diodes.
Design Notes
  • RMS-to-DC Conversion Just Got Easy &mdash DN288
    PDF, 82 Кб, Файл опубликован: 2 июн 2002
  • An Autoranging True RMS Converter &mdash DN339
    PDF, 77 Кб, Файл опубликован: 1 июн 2004
Статьи
  • Delta Sigma Breakthrough: LTC1966 True RMS-to-DC Converter Uses No Diodes, Heaters or Logarithms &mdash LT Journal
    PDF, 270 Кб, Файл опубликован: 1 мар 2002
  • Signal Conditioning > RMS-DC Conversion
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) System Monitor
LTC1966HMS8TRPBF, LTC1966HMS8 TRPBF
На английском языке: Datasheet Linear Technology LTC1966HMS8#TRPBF
