Datasheet Linear Technology LTC1968IMS8#TRPBF — Даташит
Серия | LTC1968 |
Модель | LTC1968IMS8#TRPBF |
Прецизионный широкополосный преобразователь среднеквадратического значения в постоянный ток
LTC1968: Precision Wide Bandwidth, RMS-to-DC Converter
PDF, 303 Кб, Файл закачен: 15 авг 2017
![]() 17 предложений от 14 поставщиков Активная деталь, RMS to DC Converter 1.05V 2700uA 8Pin MSOP T/R | |||
LTC1968IMS8#TRPBF Analog Devices | 556 ₽ | ||
LTC1968IMS8#TRPBF Linear Technology | 734 ₽ | ||
LTC1968IMS8#TRPBF Analog Devices | 870 ₽ | ||
LTC1968IMS8#TRPBF Linear Technology | 966 ₽ |
Корпус | MS-8 |
Код корпуса | MS8 |
Индекс корпуса | 05-08-1660 |
1% Error Bandwidth | 500 kHz |
3dB Error Bandwidth | 15000 kHz |
Conversion Gain Error | 0.1 % |
Demo Boards | DC427B-C |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Isupply | 2.3 мА |
Нелинейность | 0.02 % |
Vin Max | 1.05 В |
Vs макс. | 6 В |
Vs мин. | 4.5 В |
- Instrumentation Circuitry Using RMS-to-DC Converters &mdash AN106PDF, 354 Кб, Файл опубликован: 21 фев 2007
It is widely acknowledged that RMS measurement of waveforms furnishes the most accurate amplitude information. Rectify-andaverage schemes, usually calibrated to a sine wave, are only accurate for one waveshape. Departures from this waveshape result in pronounced errors. Although accurate, RMS conversion often entails limited bandwidth, restricted range, complexity and difп¬Ѓcult to characterize dynamic and static errors. The LTC1966/67/68 RMS converter family addresses these issues, making instrument grade applications practical. A variety of instrumentation oriented applications are presented. Included are basic circuits, a fully isolated AC line monitor, a distortionless AC line voltage regulator, wideband X1000 pre-ampliп¬Ѓers, a quartz crystal RMS current meter, a crystal stabilized AC voltage reference, an RMS amplitude leveled random noise generator and an RMS amplitude level controller. Appended sections cover RMS theory and converter operation, AC measurement and signal handling practice, test equipment recommendations, noise theory and noise diodes.Выписка из документа
Design Notes
- Precision LVDT Signal Conditioning Using Direct RMS to DC Conversion &mdash DN362PDF, 75 Кб, Файл опубликован: 23 мар 2005Выписка из документа
Статьи
- Accurate and Simple AC Measurement to 500kHz &mdash LT JournalPDF, 166 Кб, Файл опубликован: 25 мар 2005Выписка из документа
- Low-Distortion Sine Wave Oscillator with Precise RMS Amplitude Stability &mdash LT JournalPDF, 111 Кб, Файл опубликован: 25 мар 2005Выписка из документа
Серия: LTC1968 (4)
- LTC1968CMS8#PBF LTC1968CMS8#TRPBF LTC1968IMS8#PBF LTC1968IMS8#TRPBF
- Signal Conditioning > RMS-DC Conversion
LTC1968IMS8TRPBF, LTC1968IMS8 TRPBF
