Datasheet Linear Technology LTC1968 — Даташит
СерияLTC1968
Прецизионный широкополосный преобразователь среднеквадратического значения в постоянный ток
LTC1968: Precision Wide Bandwidth, RMS-to-DC Converter
PDF, 303 Кб, Файл закачен: 15 авг 2017
15 предложений от 15 поставщиков
Активная деталь, RMS to DC Converter 1.05V 2700uA 8Pin MSOP
LTC1968CMS8
326 ₽
LTC1968CMS8
481 ₽
LTC1968IMS8
703 ₽
LTC1968IMS8
LTC1968CMS8#PBFLTC1968CMS8#TRPBFLTC1968IMS8#PBFLTC1968IMS8#TRPBF
N1234
КорпусMS-8
Габаритный чертеж корпуса
MS-8
MS-8
MS-8
Код корпусаMS8MS8MS8MS8
Индекс корпуса05-08-166005-08-166005-08-166005-08-1660
Количество выводов8888
Parameters / ModelsLTC1968CMS8#PBFLTC1968CMS8#TRPBFLTC1968IMS8#PBFLTC1968IMS8#TRPBF
1% Error Bandwidth, kHz500500500500
3dB Error Bandwidth, kHz15000150001500015000
Conversion Gain Error, %0.10.10.10.1
Demo BoardsDC427B-CDC427B-CDC427B-CDC427B-C
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнетнет
Isupply, мА2.32.32.32.3
Нелинейность, %0.020.020.020.02
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от -40 до 85от -40 до 85
Vin Max, В1.051.051.051.05
Vs макс., В6666
Vs мин., В4.54.54.54.5
RoHSСовместимСовместимСовместимСовместим
  • Instrumentation Circuitry Using RMS-to-DC Converters &mdash AN106
    PDF, 354 Кб, Файл опубликован: 21 фев 2007
    It is widely acknowledged that RMS measurement of waveforms furnishes the most accurate amplitude information. Rectify-andaverage schemes, usually calibrated to a sine wave, are only accurate for one waveshape. Departures from this waveshape result in pronounced errors. Although accurate, RMS conversion often entails limited bandwidth, restricted range, complexity and difficult to characterize dynamic and static errors. The LTC1966/67/68 RMS converter family addresses these issues, making instrument grade applications practical. A variety of instrumentation oriented applications are presented. Included are basic circuits, a fully isolated AC line monitor, a distortionless AC line voltage regulator, wideband X1000 pre-amplifiers, a quartz crystal RMS current meter, a crystal stabilized AC voltage reference, an RMS amplitude leveled random noise generator and an RMS amplitude level controller. Appended sections cover RMS theory and converter operation, AC measurement and signal handling practice, test equipment recommendations, noise theory and noise diodes.
Design Notes
  • Precision LVDT Signal Conditioning Using Direct RMS to DC Conversion &mdash DN362
    PDF, 75 Кб, Файл опубликован: 23 мар 2005
Статьи
  • Accurate and Simple AC Measurement to 500kHz &mdash LT Journal
    PDF, 166 Кб, Файл опубликован: 25 мар 2005
  • Low-Distortion Sine Wave Oscillator with Precise RMS Amplitude Stability &mdash LT Journal
    PDF, 111 Кб, Файл опубликован: 25 мар 2005
  • Signal Conditioning > RMS-DC Conversion
На английском языке: Datasheet Linear Technology LTC1968
