Datasheet Linear Technology LTC1099ACN#PBF — Даташит
СерияLTC1099
МодельLTC1099ACN#PBF
Высокоскоростной 8-битный аналого-цифровой преобразователь со встроенной функцией выборки и хранения
Datasheet LTC1099
PDF, 204 Кб, Язык: анг., Файл закачен: 16 авг 2017, Страниц: 16
High Speed 8-Bit A/D Converter with Built-In Sample-and-Hold
17 предложений от 17 поставщиков
IC ADC 8BIT FLASH 20DIP. 8 Bit Analog to Digital Converter 1 Input 1 Flash 20-PDIP. Data Acquisition - Analog to...
Рутоника
LTC1099ACN#PBF
1 550 ₽
LTC1099ACN#PBF
2 608 ₽
LTC1099ACN#PBF
5 574 ₽
LTC1099ACN PBF
КорпусN-20
Код корпусаN
Индекс корпуса05-08-1510 (N20)
ADC INL0.5 LSB
ADCs1
АрхитектураSAR
Bipolar/Unipolar InputUnipolar
Bits8 bits
Количество каналов1
DNL1 LSB
Экспортный контрольнет
I/OParallel
Input DriveSingle-Ended
Input Span0V to 5V
Internal Referenceнет
Power55 mW
SINAD47 дБ
Simultaneousнет
Speed400 ksps
Диапазон напряжения питания5V
  • Converting Light to Digits: LTC1099 Half Flash 8-Bit A/D Converter Digitizes Photodiode Array &mdash AN33
    PDF, 703 Кб, Файл опубликован: 2 мар 1989
    This application note describes a Linear Technology "Half-Flash" A/D converter, the LTC1099, being connected to a 256 element line scan photodiode array. This technology adapts itself to handheld (i.e., low power) bar code readers, as well as high resolution automated machine inspection applications.
  • LTC1099 Enables PC Based Data Acquisition Board to Operate DC-20kHz &mdash AN34
    PDF, 4.7 Мб, Файл опубликован: 1 апр 1989
    A complete design for a data acquisition card for the IBM PC is detailed in this application note. Additionally, C language code is provided to allow sampling of data at speed of more than 20kHz. The speed limitation is strictly based on the execution speed of the "C" data acquisition loop. A "Turbo" XT can acquire data at speeds greater than 20kHz. Machines with 80286 and 80386 processors can go faster than 20kHz. The computer that was used as a test bed in this application was an XT running at 4.77MHz and therefore all system timing and acquisition time measurements are based on a 4.77MHz clock speed.
  • Interfacing to Microprocessor Based 5V Systems &mdash AN50
    PDF, 2.7 Мб, Файл опубликован: 23 авг 1992
    This application note discusses a variety of approaches for interfacing analog signals to 5V powered systems. Synthesizing a "rail-to-rail" op amp and scaling techniques for A/D converters are covered. A voltage-to-frequency converter, applicable where high resolution is required, is also presented.
  • Data Acquisition Circuit Collection &mdash AN62
    PDF, 349 Кб, Файл опубликован: 1 окт 1994
    This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.
  • Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Single Channel ADCs
LTC1099ACNPBF, LTC1099ACN PBF
На английском языке: Datasheet Linear Technology LTC1099ACN#PBF
Публикации по теме
