Datasheet Linear Technology LTC2400CS8#PBF — Даташит
| Серия | LTC2400 |
| Модель | LTC2400CS8#PBF |
24-битный дельта-сигма АЦП µPower без задержки в SO-8
Datasheet LTC2400
PDF, 481 Кб, Язык: анг., Файл закачен: 21 авг 2017, Страниц: 40
24-Bit µPower No Latency ∆Σ™ ADC in SO-8
Купить LTC2400CS8#PBF на РадиоЛоцман.Цены — от 254 до 1 922 ₽47 предложений от 27 поставщиков IC ADC 24BIT SIGMA-DELTA 8SOIC. 24 Bit Analog to Digital Converter 1 Input 1 Sigma-Delta 8-SOIC. Data Acquisition - Analog to... | |||
| LTC2400CS8#PBF Analog Devices | 390 ₽ | ||
| LTC2400CS8#PBF | 937 ₽ | ||
| LTC2400CS8#PBF Analog Devices | от 1 796 ₽ | ||
| LTC2400CS8#TRPBF Analog Devices | по запросу | ||
| Корпус | SO-8 |
| Код корпуса | S8 |
| Индекс корпуса | 05-08-1610 (S8) |
| ADC INL | 33.5 LSB |
| ADCs | 1 |
| Архитектура | Delta Sigma |
| Bipolar/Unipolar Input | Unipolar |
| Bits | 24 bits |
| Количество каналов | 1 |
| DNL | 1 LSB |
| Demo Boards | DC573A |
| Design Tools | Linduino File |
| Экспортный контроль | нет |
| Основные особенности | No Latency |
| I/O | Serial SPI |
| INL ppm | 2 ppm |
| Input Drive | Single-Ended |
| Input Span | -0.3V to VREF +12.5% |
| Internal Reference | нет |
| Рабочий диапазон температур | от 0 до 70 °C |
| Power | 1 mW |
| Simultaneous | нет |
| Speed | 0.0075 ksps |
| Диапазон напряжения питания | 2.7V to 5.5V |
- A Collection of Differential to Single-Ended Signal Conditioning Circuits for Use with the LTC2400, a 24-Bit No Latency Delta Sigma ADC in an SO-8 &mdash AN78PDF, 177 Кб, Файл опубликован: 7 авг 1999
This application note describes six low power differential-tosingle- ended signal conditioning circuits for the LTC2400 No Latency ΔΣTM 24-bit ADC. These circuits offer the customer a number of choices for conditioning differential input signals as low as 5mV to as high as ±2.5V, as well as operation on a single 5V or ±5V supplies. Each circuit description also covers circuit design and implementation techniques that can help preserve the LTC2400's inherently high effective resolution. AN78 concludes with two circuits for digitizing temperature when using an RTD or Type S thermocouple.Выписка из документа - How to Use the Worlds Smallest 24-Bit No Latency Delta-Sigma ADC to its Fullest Potential &mdash AN80PDF, 81 Кб, Файл опубликован: 1 июл 1999
Linear Technology's LTC2400 is the world's first 24-bit ADC in an SO-8 package. An innovative new delta-sigma architecture has been developed. The result is a small, highly accurate, simple-to-use delta-sigma ADC. This Application Note was created to educate users on several topics associated with delta-sigma converters and to dispel confusion associated with this new oneshot, or No Latency ΔΣTM architecture. The key topics addressed include speed, noise, PGAs line frequency rejection, input current, multiplexing, analog input range and key features differentiating the LTC2400 from other delta-sigma ADCs.Выписка из документа - A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86PDF, 540 Кб, Файл опубликован: 1 янв 2001
This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.Выписка из документа - Delta Sigma ADC Bridge Measurement Techniques &mdash AN96PDF, 232 Кб, Файл опубликован: 17 янв 2005
AN96 features several applications that demonstrate how to take full advantage of Linear Technology's delta sigma ADCs when interfacing to sensors. In many cases, signal conditioning can be greatly simplified or eliminated completely. This note explains where it is appropriate to use amplifiers and how to optimize amplifier gain. Also included are discussions on measuring effective number of bits (ENOB) and the relationship to instrument performance, frequency response of delta sigma ADCs, and test techniques. C source code for all of the applications is included to aid firmware development.Выписка из документа
Design Notes
- Testing Linearity of the LTC2400 24-Bit No Latency Delta SigmaTM A/D Converter Help from the Nineteenth Century &mdash Design Solutions 11PDF, 51 Кб, Файл опубликован: 1 ноя 1999Выписка из документа
Статьи
- 1- and 2-Channel, No Latency Delta Sigma , 24-Bit ADCs Easily Digitize a Variety of Sensors &mdash LT JournalPDF, 209 Кб, Файл опубликован: 1 фев 2000Выписка из документа
- LTC2400 Differential Bridge Digitizers &mdash LT JournalPDF, 120 Кб, Файл опубликован: 1 июн 1999Выписка из документа
- No Latency Delta-Sigma ADC Techniques for Optimized Performance &mdash LT JournalPDF, 239 Кб, Файл опубликован: 1 май 2001Выписка из документа
- World &mdash LT JournalPDF, 417 Кб, Файл опубликован: 1 ноя 1998Выписка из документа
Серия: LTC2400 (4)
- LTC2400CS8#PBF LTC2400CS8#TRPBF LTC2400IS8#PBF LTC2400IS8#TRPBF
- Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Single Channel ADCs
LTC2400CS8PBF, LTC2400CS8 PBF
